Question on 1st gen EGR valve
Old Sep 18, 2016 | 07:52 PM
codenamezero's Avatar
I took out my EGR, trying to clean it, but i can't seem to be able to push the valve down at all. I've seen some video on EGR valve and they seems to be able to push the valve easily... is mine completely stuck? Or there is a very stiff spring holding it?
Old Sep 18, 2016 | 10:55 PM
ezone's Avatar
The Honda valves pintle does not push in. It extends outward when it opens.
The valve itself is not a usual problem, but the passages and ports in the intake manifold tend to clog.
Old Sep 20, 2016 | 03:59 PM
I already opened up the intake port and they looked fine, the only other place left is really the EGR. Does anyone know how to hook the pins up so that I can manually activate the EGR valve?
Old Sep 20, 2016 | 07:36 PM
ezone's Avatar
What fault code do you have?
Terminals 4 (pink) and 6 (black, ground) operate the valve
The other 3 wires are for the positions sensor.
Old Sep 21, 2016 | 08:23 AM
I don't have any code, but the car would misfire or stutter at high rpm or at idle.
Steven Hung
16
Feb 17, 2019 03:42 AM
Kevin Evans
Feb 11, 2018 10:48 AM
amberd03
Aug 20, 2017 11:57 AM
Lamak
Mar 15, 2009 03:24 AM
