engine tempreture hot
Old Jan 11, 2017 | 02:09 AM
mat77's Avatar
hi, my jazz engine temp gauge hot, i notice coolent overflow from expansion tank ,already replace thermostat, radiator cap and water pump,,,,, any idea?
Old Jan 11, 2017 | 02:43 AM
macbuddy's Avatar
Check that your radiator cores are free of obstruction. A plugged up radiator could also cause overheating.
Old Jan 11, 2017 | 03:03 AM
mat77's Avatar
i try that this weekend, thanks
Old Jan 11, 2017 | 03:31 AM
n9cv's Avatar
Use an air hose and blow air backwards (Inside by the engine and out the front of the radiator ).
Old Jan 11, 2017 | 08:19 PM
DrewE's Avatar
It wouldn't hurt to also check that the radiator fan comes on properly. They certainly should be operating if the engine temperature is high enough for the light to come on.
I'd also check that the radiator hoses aren't collapsing (particularly the return hose).
If everything else checks out, the water pump would seem to be the logical cause by a process of elimination.
Old Jan 12, 2017 | 09:48 AM
Carbuff2's Avatar
^^ But, he already replaced the Water Pump...
dave1a2003
Jan 10, 2024 05:32 PM
willfit07
Nov 21, 2016 05:25 AM
john21031
Nov 26, 2015 01:39 AM
Jeff Pirkey
Feb 5, 2012 11:06 AM
Krystyne
Sep 30, 2005 04:36 PM
