air filter, engine, Fit 2007
Old Jan 22, 2017 | 04:49 PM
georgi6's Avatar
The cover of the housing won't get out on my Fit 2007. I released the 4 clips, I lifted a bit the front end of the cover but something retain the rear side. Is it possible the air filter to be wrongly mounted and now to block the move of the cover?
Old Jan 22, 2017 | 06:59 PM
Dean's Avatar
Old Jan 22, 2017 | 10:29 PM
georgi6's Avatar
I did the same but it won't get out.
Old Jan 23, 2017 | 07:47 AM
Hootie's Avatar
Are you sure that the air filter wasn't installed upside down? I've seen that happen a few times and the air box's lid will be a bit difficult to remove without a little extra effort.
Old Jan 23, 2017 | 05:11 PM
Dean's Avatar
curious if previous owner or a shop glued the pipe to the intake box for some ill advised reason?
Old Jan 23, 2017 | 11:11 PM
georgi6's Avatar
After an hour fight with the lid, trying not to brake it , I remove it and found the filter mounted upside down. It is Y1307 - no signs how to install or direction of the air.
upside down
correct
Old Jan 30, 2017 | 11:28 PM
doctor J's Avatar
When Jiffy lube installed air filter upside down on 91 Camry v-6 the engine was running VERY rich!
Odie
Nov 1, 2017 04:02 PM
bigsmitty
Jul 14, 2017 07:17 PM
nogoengr
Feb 12, 2017 06:16 PM
rodney
May 12, 2016 02:02 AM
frossie
Apr 18, 2006 07:14 PM
