07 hesitation issue
Old Mar 23, 2017 | 11:03 PM
McNally's Avatar
07 hesitation issue
Hello,
Has anyone had issues with a stutter or hesitation with 07 fits? My fit has about 160,000 miles and is still in good shape overall but ever once in a while it will lack power. I have been using 89 octane lately because 87 octane seems to act up more. Please advise if you have similar issues and/or remedies. Thanks in advance!
Old Mar 24, 2017 | 02:13 PM
Carbuff2's Avatar
Search "constant speed stutter" or Coil Packs and get back to us in a couple days... GRIN.
Old Mar 24, 2017 | 02:14 PM
nosewitdot's Avatar
I have an 07 MT with ~170K miles as well.
This tends to happen to mine on cold start and will stutter and even stall sometimes. What I find is that letting the car warm-up and drop the idle a bit will stop this from happening.
From what I've read on here some suggest a valve adjustment.
I'm sure I need some sort of tune, valve adjustment or carb clean treatment. I haven't really done anything else to the fit beside the routine oil and filter changes.
Old Mar 25, 2017 | 02:18 AM
dwtaylorpdx's Avatar
The longer you let a car go, the more likely the results get worse.
Main reasons coil packs die is corrosion, and too high of current draw when firing. The high current comes from the spark plugs aging and the weak firing due to valve adjustment. Some folks get lucky and the magic combo of nice hard valves and seats and a harder average camtrain make them last a long time.. That's not the majority. You likely could pay for the tune-up and valve adjust with the fuel savings over the long haul. After all we are talking about 250 bucks every 60 to 80 K miles..
Good luck.
inkeye
Nov 3, 2016 06:37 PM
Stopshaking
Dec 23, 2015 12:47 AM
UnicycleWheelie
Mar 8, 2014 11:28 PM
kharissa_g
Oct 24, 2013 03:32 AM
gfrobe
Dec 19, 2012 03:58 PM
