my car has the stank
Old Aug 10, 2017 | 10:33 PM
bach's Avatar
My car has developed the moldy stank coming from the vents. It's not overpowering but yeah, it's there. I usually detect it a few minutes after I get rolling. Sometimes it lingers a bit before dissipating. I don't use the AC that much and when I do I'm pretty good about cutting the condenser a few blocks before my destination so I'm kind of surprised and also disappointed. Surprised because duh Honda. Disappointed because I'm thinking it means I have a moisture problem that I'm going to have to look into. Sigh.
Old Aug 10, 2017 | 11:09 PM
wasserball's Avatar
Your moisture drain line under the car must be stuck. I wonder if you lift the car, and if there is a way to inject bleach up the line that would clear the moldy smell. In home AC, I pour a cup of bleach into the bypass drain line because the main drain line is plugged by mold. I have two AC. One for upstairs and one downstairs. I used the American philosophy. If one cup is good two cups is better. The AC guy wanted $175 to flush the lines, but I said over my dead body, not.
Old Aug 11, 2017 | 12:42 AM
first honda's Avatar
Hmmm. I get a funky smell after I turn AC off and run just the fan but goes a way and won't stink with fan only until next time I use AC again. Was going to ask dealer on my first oil change.
Old Aug 11, 2017 | 08:07 AM
yah just keep the ac turned on at all times.
my wife turns it off on occasion and ends up with the funky smell. just keep it on.
if it continues check the drain under the car. there is a tube on the passenger side pointing down
Old Aug 11, 2017 | 08:10 AM
bleach is okay if you can wash it out. if not it will corrode metals and possibly break up seals..
Old Aug 11, 2017 | 08:11 AM
.. and ur car will smell like a swimming pool. maybe
or a freshly cleaned toilet at best?
Old Aug 11, 2017 | 09:12 AM
wasserball's Avatar
Old Aug 12, 2017 | 01:30 PM
bach's Avatar
So I went to the dealer today to get the oil changed and we talked about the stank. Maybe he was blowing me off but he says it's a common thing and if anything was blocked up the passenger floor would be wet enough that it would be noticed. So I'm going to try the Lysol in the intake like the youtube video and go from there ... hopefully it's a long-term fix but we'll see.
Old Aug 12, 2017 | 01:32 PM
that is true that the floor would be wet if it was that moldy smelling all the time with the drain plugged up. if the smell is only time to time, just keep the AC turned on at all times as noted on my earlier post.
Old Aug 13, 2017 | 09:20 AM
bach's Avatar
Wow, I'd be afraid I'd burn out the condenser if I ran it constantly, esp. when it's not needed ...
Old Aug 13, 2017 | 12:05 PM
dont worry. i ran a/c 100% of the time on my GD, GE, and GK no issue.
plus cars with auto climate control run a/c all the time. (i mean it cycles on/off on its own but you know what i mean)
plus, it's better to cycle a/c routinely. ive had a/c problems on cars that i didnt run most of the time.
Old Aug 13, 2017 | 02:58 PM
exl500's Avatar
Think Florida. It's very rarely off.
Old Aug 13, 2017 | 03:31 PM
4d3fect's Avatar
I live in Cali, and I have mine on most of the time anyway, not full blast or anything. I don't see it developing into a problem before something else more serious happens.
Roger's Fit
May 28, 2021 11:55 AM
psamtik
Jun 26, 2018 11:39 AM
CuTeBoi
Oct 2, 2016 04:35 PM
jlatus
Oct 7, 2012 10:06 AM
Vash
Sep 12, 2010 11:56 PM
