Radiator fan
Old Oct 8, 2017 | 07:16 PM
gerard6496's Avatar
Radiator fan
Can anybody out there driving a 2007 or 2008 Fit tell me how often and under what conditions they hear their radiator fan come on? I just replaced a head gasket on my 2008, and I don't hear my radiator fan coming on. My a/c fan comes on as soon as I turn on the a/c. I checked the radiator fan motor, coolant sensors 1and 2, and fan relay, thermostat and they all check good.
Old Oct 8, 2017 | 09:08 PM
doctor J's Avatar
Both fans should be on or off simultaneously, not just one.
the coolant thermo-sensor at the bottom tank of the radiator controls fan operation (for cooling)
Old Oct 9, 2017 | 04:42 AM
gerard6496's Avatar
Radiator fan
So when the A/C is off, and the engine gets hot, both fans turn on?
Old Oct 9, 2017 | 05:53 PM
doctor J's Avatar
Yes,exactly!
Old Oct 11, 2017 | 05:49 AM
gerard6496's Avatar
If the coolant thermo-sensor( ECT2) at the bottom tank of the radiator controls fan operation of both the a/c and the engine radiator fans, what does the coolant temp sensor (ECT 1) up in the head by the thermostat do?
Old Oct 11, 2017 | 01:46 PM
ezone's Avatar
Primary fuel injection calculations
Old Oct 11, 2017 | 04:50 PM
gerard6496's Avatar
radiator fans
Thanks everybody for the replys!
Old Oct 12, 2017 | 12:52 AM
dwtaylorpdx's Avatar
Read my head gasket tour thread,, same issue, the GD does not turn the fans on till like 230 on the sensor,,, I added a 190 thermo-switch relay and tied it to the driver side fan wire. Keeps the car under 200 nicely, usually about the 185 just like the thermostat in the engine wants..
Old Oct 12, 2017 | 04:19 AM
gerard6496's Avatar
Radiator fan
Perhaps tricking the ECM to turning on the rad. fan early by a lower value ECT2?
Old Jan 12, 2024 | 02:12 AM
Eriksen's Avatar
"Both fans should be on or off simultaneously, not just one.
the coolant thermo-sensor at the bottom tank of the radiator controls fan operation (for cooling)"
Does this also apply to a Honda jazz/fit from 2013? Since I can't find any other fan switch. Best regards Erik
mangosmoody
Jun 19, 2016 07:38 PM
Oofie
Jun 18, 2011 05:50 PM
fit4jdm
Oct 21, 2008 01:39 AM
Edward Man
Oct 16, 2006 10:53 PM
Al Davis
May 15, 2005 07:30 PM
