replacing cam chain 2007 fit
Old Oct 16, 2017 | 01:35 PM
idrizmiftari's Avatar
Hello all,
I started to hear an odd sound coming from my 2007 fit engine so I decided to replace the chain/tensioners in hopes of fixing the sound. I had removed the chain case and got stuck. In the instructions and guides online they mention to remove the cam sprockets; however the bottom sprocket has a sprocket case that extends past the oil pan. I am unsure how to remove the sprocket case. In all the guides, there is no mention of a sprocket case. I was thinking of using a grinder to cut the whole thing off, but wanted to see if I was missing something obvious.
Old Oct 16, 2017 | 07:00 PM
sneefy's Avatar
Drop the oil pan maybe?
​​​​​​I wouldn't use a grinder and get metal shavings all over.
idrizmiftari
Oct 16, 2017 02:27 PM
mrbill47
Apr 24, 2017 12:06 PM
lrf487
May 26, 2009 06:38 AM
dannymai
Greater Calgary Community
Nov 5, 2007 12:49 AM
