Door locks not activating by alarm.
Old Nov 3, 2017 | 03:58 AM
styg's Avatar
Hi guys, I've searched for some posts here but couldn't find anything related to this.
I installed a alarm in my Fit 05 and after hours spent on it I could identify and connect basically everything and it's all working fine, except for the door locks, when I press the remote control my alarm central is sending a negative pulse to arm or disarm the door lock (two different wires) but the door lock doesn't respond to it.
So, if someone has already dealt with this, I'd like to know:
1) Am I using the right wires to arm/disarm?
Looking at the diagram below, I'm connecting the alarm's arm/disarm outputs to the YEL/RED, WHT/BLK wires.
Wiring Diagram
I identified those wires with a multimeter, they're coming from the door actuator with 3 more wires, and when activating the door pin to lock/unlock the door, these two wires keep alternating who is on negative.
I thought that the alarm's output wasn't strong enough to activate the actuator but then I tried to short circuited one of these wires to negative to see if the actuator would switch between lock/unlock but nothing as well.
So, I kind of ran out of ideas for what to do.
Any guess??
MoonDance
May 23, 2018 01:30 PM
her_fedo
Sep 6, 2010 09:52 AM
Poncho
Feb 29, 2008 01:14 PM
Amageus
Jan 2, 2008 03:26 AM
Rdean58
Aug 3, 2007 08:29 AM
