1st Gen Keyless Entry
Old Dec 20, 2017 | 12:13 PM
Chris Murray's Avatar
I've got an '07 Fit that's experiencing the common sticky door lock problem. I decided to install keyless entry. Because it's NLA from dealers, I ordered from the Internet. The harness (08E50-SLN-100) went in fine, but the problem is the security unit that attaches by the fuse block. The module I got has a green 5 pin connector, but the harness has a green 7 pin connector. The easiest thing to do is get a module with 7 pins, but I can't find what year and/or model uses 7 pins. The 5 pin module (38385-SAA-A01) seems to fit the '06 CR-V. Any one got any ideas or am I SOL?
Chris
Old Nov 22, 2022 | 04:21 PM
acidcypher's Avatar
you need the fit security unit. It will plug right into the keyless entry if it is correct for your system. If you are not using your keyless module, and still have it, id gladly buy it. adam.black_09@yahoo.com
Keyless Module 08E60-SLN-100
Add-on security module 08E50-SLN-100
urbansuburbia
Feb 15, 2024 03:14 PM
cuban8
Aug 15, 2018 09:13 AM
07hatchfit
Feb 29, 2016 07:15 PM
eriko
Jan 22, 2010 02:19 PM
ex99125b
Jan 14, 2009 03:00 PM
