MPG plunges from 70 MPH to 80 MPH -- do other cars do this?
Old May 16, 2018 | 08:20 PM
larrymcewin's Avatar
I drive to Los Angeles quite a bit. I generally set the cruise at 80 MPH and consistently get about 33-34 MPG. On a recent trip, I set the cruise to just 70 MPH and found I got 39-40 MPG. A jaw-dropping improvement. (My Fit is the 5MT).
Is the Fit just a weird shape (tall)? It seemed like the old 2000 Toyota Corolla I could cruise along at 90 MPH and get 40 MPG on the freeway.
Thoughts from your experience?
Old May 16, 2018 | 11:29 PM
ezone's Avatar
Absolutely.
Wind resistance increases at an exponential rate as your speed increases.
My daily is a 12 Civic.
At steady 55 MPH I can get over 40 MPG.
(on the original wheels and tires I managed to get like 53 MPG--strictly highway)
At 80-85+ on the interstates it can drop to less than 30 MPG.
Of course city stop and go traffic immediately kills those high numbers.
Old May 17, 2018 | 06:00 AM
spike55_bmw's Avatar
I have an Ultraguage monitor plugged into my OBDII and I can watch fuel consumption in Gallons per Hour (Gals/Hr). It "says" that it is in the +3 Gals/Hr range around 80 mph and up. In the +/- 60 mph range, it "says" it is less than 2 Gals/Hr.
There might be an interesting graph in my future.
Old May 17, 2018 | 11:07 AM
Illuminator's Avatar
The little motor in the Fit just has to work really hard doing 80. I regularly take my Fit on road trips, and 80 just tanks the MPG's. I get about 33-34 to Santa Fe.
By contrast, my 2012 Focus (I think it's 2.0 litre) gets worse in town mileage, but substantially better highway mileage, because that motor isn't working quite so hard to do 80. It's got about 40 more horsepower and I'm not sure how much more torque. I get about 38-40 to Santa Fe.
Old May 17, 2018 | 01:37 PM
Andrei_ierdnA's Avatar
It's perfectly normal with the Fit and all other boxy shaped cars. The faster you go, the more you will notice this. Your 2000 Corolla was more aerodynamic than any generation of the Fits.
If you have the time & patience you should try once to set the cruise at 60-65 MPH and you can expect 45 MPG.
I have a SGII always plugged in and I like to monitor my instant and average fuel mileage most of the time I'm driving. I can tell you for sure that driving on cruise is worse for fuel economy than driving with your foot on the pedal, especially if there are any hills. I don't drive on completely flat roads, so I don't know if things would equal out more on flat lands.
Old May 18, 2018 | 10:37 AM
fitchet's Avatar
Sometimes with coefficient of drag, it's not so much size as it is shape.
According to a Road and Track review of the 2015 Honda Fit, the coefficient of drag was improved on the Honda Fit, even though no numbers are offered.
With under plating, and an oval wedge shape, my guess would be the Honda Fit actually has a very good coefficient of drag.
I'd much more explain the dive in MPG in a Fit at 80 mph, as being caused by going 80 mph...in a 4 cylinder Honda Fit.
The more you tax the engine, the harder it works, the less fuel economy you will get.
Old May 18, 2018 | 12:15 PM
GAFIT's Avatar
Add the 4.62 final drive ratio for the GE Fit into the equation as well. Turns more rpm on the highway than most sport bikes and doesn't have a high revving motor.
Old May 18, 2018 | 12:31 PM
the Fit does fantastic up to about 65mph. then drag and all just eats up the mpg.
this is why i say the Fit is a great surface road car.
Old May 18, 2018 | 12:44 PM
evilchargerfan's Avatar
MEGA off topic.... have any of you scan gauge, and ultra gauge users ..... had the honor of testing out BOTH products? I'd like to see if theres any benefit of going with the scangauge, as it is 2x more expensive than the ultra guage. I value your input gents/ladies
Old May 18, 2018 | 06:18 PM
Brain Champagne's Avatar
I think that having a relatively flat back, vs. a trunk, makes it less aerodynamic.
Old May 19, 2018 | 12:35 PM
i dont see the point of those obd2 monitors. might be a fun toy for a few months but unless ure using it to read dtc's and wat not, they are honestly meaningless. ull forget to even look at it after a while.
Old May 19, 2018 | 12:49 PM
GAFIT's Avatar
I kind of agree. Without the ability to alter the ECU programming, they are mostly novelty unless you're using them to absolutely maximize fuel mileage.
Back to the OP. I would say that all cars do it, but the speed at which it happens varies greatly. I've noticed very little economy difference between cruise set at 70mph and cruise set at much higher speeds in my Lincoln. At 100mph it's still turning under 2500 rpm and isn't in boost. Push it much past that and it starts needing boost to overcome the wind resistance.
It gets between 25 and 27mpg on the highway. Neither are great mileage, but it's about the same either way.
The pick up trucks I've owned have been the most drastic for speed vs economy. They have to move so much air that they just become incrementally less efficient with every 1mph increase in speed it seems.
Old May 19, 2018 | 01:15 PM
ezone's Avatar
Many of us don't have a temp gauge on the dash. That was the main reason I got an ultragauge for my car.
Plus, I'm a tech and I like to be able to see live data sometimes, even if the UG can't display all parameters that I would like to see.
Old May 19, 2018 | 01:19 PM
GAFIT's Avatar
I did the same thing, but to his point, once I found what the car runs at over the course of a few drives, I never looked at it again.
If the high temp light ever comes on, I'll plug it back in to check.
That being said, it's really just a fault of our cars that we don't have adequate gauges. Most cars show you all vitals with the factory gauges.
Old May 19, 2018 | 02:34 PM
fitchet's Avatar
I honestly don't know. Because Honda isn't readily making the the drag coefficient numbers available.
But I do know, The Toyota Prius has a low coefficient of drag by design.
That oval wedge shape, does great in a wind tunnel.
And The Fit really embraces a similar shape.
There aren't a lot of squared edges on The Fit.
To me?
Non-Aerodynamic "penalty" comes in with vehicles like the KIA Soul. Now that is a non-aerodynamic box. And still it get's pretty good MPG.
I'm convinced the loss of MPG in this case has much more to do with driving at 80 mph than anything else.
Old May 20, 2018 | 11:57 AM
I'll keep this reply simple, in an effort to not clutter the thread
there's more to a scangauge than novelty. it provides live data, its damn useful. example... when I go to work and climb a steep hill.... should I keep it in 3rd gear? should I keep it in 4th gear? how fast should I go? the gauge tells me (live), my mpg is X when I'm going X mph in 3rd gear. and then, I would test it again in 4th gear instead and see what the impact is on mpg. for those who care about mpg, its useful. cleanmpg, ecomodders, and a few other forums may give better insight as I havent owned my for long. and hence, why I asked if the UltraGauge is any better... cause its like 2x cheaper
I will say tho ... most of us can get by with the oem "0 - 45 mpg - 90 mpg" gauge just fine....
Old May 24, 2018 | 01:48 PM
The flat back of the Fit is the biggest un-aerodynamic feature.
Sure the back part of the car narrows down a bit into a kammback feature (similar to a Prius), but it's simply not long & narrow enough to be all that effective, so it's still very much a flat back car.
Sure that making all corners smooth & round helps a bit, but the overall shape plays a much larger role than minor items like bumpers, headlights, corners, etc
Here's the most aerodynamic car shape:
As you can see from the 'rain drop' design, the Fit is not aerodynamic at all.
Unless you drive it in reverse!!!
I've been using my ScanGuage2 for 3-4 years (since my old car) and love it. But I'm usually trying to maximize my MPG and it helps a lot.
The parameters I always look at are:
* instantaneous MPG
* average MPG per trip (the car's computer is optimistic by 5-10% most of the times, while the SGII can be calibrated to match exactly with pump results)
* oil/coolant temperature (especially since I use lower grille block in the winter)
* engine load (since it's MT and don't want to ever lug the engine by mistake)
I generally like seeing all the different parameters in real time under various driving conditions.
I've never used the UltraGuage but picked the SGII instead because it looks more inconspicuous and a lot less desirable than the UG, so it's easier to 'hide' in plain sight and never worry about thieves.
Also the SGII has more features and reads more parameters than the UG, which is why you basically pay more.
Old Apr 26, 2019 | 11:29 PM
OpenRoad's Avatar
Faster is better; Every car is different
Aerodynamic it is. Especially if you're attempting to get your wheels off the ground and slip the surly bonds of earth.
From zero to around 45 MPH, your MPG is mostly affected by rolling resistance. (Tire/road friction, wheel bearings, etc.) Above 45 MPG wind resistance becomes more important. Wind resistance includes factors such as frontal area and general "streamlining". Often overlooked are drag components such as roof racks, mud flaps and anything else that protrudes from the body. Turbulence under/around the vehicle also contributes to drag and can be lessened by front bumper air dams, side skirts, reduced grille opening, wheel covers etc.
Bottom line: Every car is different. Your fancy alloy wheels might be sucking 1/2 MPG at high speeds while the base model wheel covers might actually add a little MPG. And, I assume, that all of you who rely on instrumentation to provide MPG readings calibrate your instruments regularly to match real-world results.
'12Fit
Jul 10, 2012 04:05 AM
fx1367
Jan 29, 2009 09:50 AM
smartpolak88
Dec 3, 2008 11:47 AM
NMG
Aug 20, 2007 06:42 PM
Doc Holliday
Aug 1, 2007 11:59 AM
