2015 Honda Fit Service questions
Hi All!
My 2015 Honda Fit has 67k miles on it and going strong. Love this car to death! A few questions regarding servicing my Fit. I haven't gotten any tune-ups yet but I get an oil change every 7k miles. Can you guys let me know when I should replace:
1) Spark Plugs
2) Timing Belt
3) Brake Pads/Rotors
4) Brake Drums
I want to do all these myself as I would like to learn it. Also, is there anything I am missing? Thanks in advance for all the feedback!
1) Spark Plugs
2) Timing Belt
4) Brake Drums
DOWNLOAD SERVICE MANUAL HERE ---> https://techinfo.honda.com/rjanisis/...999O00132A.pdf
I believe, this topic may have already been covered:
https://www.fitfreak.net/forums/3rd-...-schedule.html
BUT .... just in case .... you dont want to read through all of that .... I'll play along:
https://www.southpointhonda.com/hond...e-schedule.htm
HONDA RECOMMENDED MAINTENANCE SCHEDULE
7,500 - 22,500 - 37,500 - 52,500 - 67,500 - 82,500 mile maintenance
15,000 - 45,000 - 75,000 - 105,000 mile maintenance
- Oil and filter change
- Inspect brakes for wear
- Lubricate throttle linkage
- Check and correct fluid levels
- Inspect tires and set tire pressure
- Rotate tires
- Lubricate chassis and hinges as required
- Replace oil drain plug, gasket
- Rotate and balance wheels and tires
- Inspect undercarriage
- Inspect crankcase filter
- Inspect shocks and struts
- Torque throttle body mount bolts
- Inspect throttle leakage
- Check and adjust clutch pedal freeplay as applicable
- Inspect distributor cap-rotor-wires
- Inspect A/C and heater operation
- Service transmission
- Check park brake adjustment
- Inspect all lights and wipers
- Replace air filter
- Inspect for trans. leaks
- Level control
- Steering systems
- Fuel and break systems
- Replace spark plugs (if necessary)
- Inspect and adjust drive belts
- Inspect air filter elements
- Rotate tires
- Inspect brake system
- Adjust parking brake
- Check all exterior and interior lamps, windshield washer systems
- Lubricate throttle shafts
- Inspect drive shaft boots
- Inspect differential oil
- Inspect exhaust pipes and mountings
- Inspect steering gear box
- Inspect steering wheel, linkage, and boots
- Inspect road test vehicle
- Inspect ball joints and dust covers
- Inspect brake lines and hoses
- Inspect brake linings/drums and brake pads/discs
- Inspect automatic transmission fluid
- Replace windshield wiper insert(s)
- Re-torque drive shaft bolt
- Re-torque propeller shaft bolt
- Lubricate all hinges and latches, door locks and door weather-strips
- Lubricate propeller shaft
- Replace air conditioning filter
30,000 - 60,000 - 90,000 - 120,000 mile maintenance
- Replace engine air filter
- Inspect for leaks
- Level control
- Replace engine coolant
- Inspect drive belts and adjustment
- Inspect brakes (visual)
- Service PCV valve
- Replace fuel filter
- Service battery and clean cables
- Inspect exhaust system
- Inspect brake line and hoses
- Differential oil
- Inspect fuel tank cap gasket
- Inspect steering wheel, linkage and boots
- Inspect transmission fluid or oil
- Inspect fuel lines & connections; fuel tank band & fuel tank vapor vent system hoses
- Inspect transfer case oil
- Lubricate wheel bearings
- Lubricate wheel bearings and drive shaft bearings
- Road test and quality control
- Automatic transmission oil and filter change
- Air filter replacement
- Spark plug replacement
- Propeller shaft flex coupling inspection
- Inspect parking brake for free play
- Visually inspect battery and clean terminals
- Inspect tire pressure and condition
- Inspect coolant hoses and clamps
- Inspect fuel lines and connections
- Inspect engine valve clearance
Soon2015FitWillBeMine
Jul 23, 2024 07:57 AM
Buck Fitty
Jun 5, 2014 11:37 AM
