09 honda fit winter tires
Hi I'm new to the forum. I have a 09 honda fit 1.5. The OEM tires are 175-65-r15 and I'm looking for 185-65-15 winter tires. Do the tires fit my fit without issues?
thanks
thanks
I'm looking for 185/65-15 though. Is it the same as the 185/60-15? Thanks for answering me.
I am going to say you are “probably” fine. The tires are taller but not hugely different. The width should be fine as well. On the EX with 185/55/16 the wheel offset is 5mm more which will change the clearances a bit but you should still be fine.
ren hoek
Apr 21, 2009 02:00 AM
