Failed Mirror Switch Assembly
Old Dec 4, 2018 | 01:01 PM
justus's Avatar
Hello,
The mirror switch assembly on a 2009 Honda Fit(base model) seems to have failed....
Neither mirror works in any direction from the adjuster pad.......
The switch assembly is located on the dashboard......
Is there any troubleshooting on this I should do? Is there a fuse? if so, where? Etc. Etc......
Any suggestions regarding remedying this situation would be greatly appreciated....
I have not purchased a new switch yet. So, even best place to purchase parts would be great...(if in fact it is the switch --- Are these prone to failure?????)
Thanks, Just
Old Dec 6, 2018 | 04:41 AM
Black3sr's Avatar
Check the fuse first. The fuse panel is behind left lower dash panel. It is No. 10 (7.5 A) fuse.
Now may sound stupid but you do have the ignition on when trying to adjust?
Old Dec 6, 2018 | 08:21 AM
spike55_bmw's Avatar
I agree with Black3sr. Check out the easy stuff first like a blown fuse before buying anything other than a volt-ohmmeter. .
Old Dec 8, 2018 | 11:53 PM
justus's Avatar
Yeah, I will check the fuse. #10 Thanks!
In any event, I am not that optimistic......
What does it take to get that switch assembly out of the dashboard?
Can anyone highlight what I am in for?
Thanks, J
Old Dec 9, 2018 | 11:31 PM
justus's Avatar
AYE!
I figured I would let you know how this panned out.....
I pulled the lower skirt off under the dash to check for fuses.....
and I figured I would shine a light up in dash and see what the back of the switch looks like
WELL,,,, IT LOOKS UNPLUGGED!.....
I was like WHAT!..... could it be that easy!
So I plugged it in........ I seemed to be working fine after that......
I will try it again..... tomorrow.......... even though I have the mirrors adjusted nice nice now
Regards J
Old Dec 10, 2018 | 04:38 AM
Black3sr's Avatar
Whew. Nice!
Old Dec 10, 2018 | 01:17 PM
justus's Avatar
Yeah, Glad I looked up in there........
And it is pretty vacant (empty real-estate) so I was able twist my head and neck with some good light up in there and see clearly.....
STRANGE though that it was disconnected... It clipped in fine when I plugged it in.. I heard it click in....
I just wonder (either someone was in their in the past) OR when the car was built (they didn't push it in enough to get it to CLICK)
Thor667
Jul 10, 2021 05:39 AM
supersuave89
Nov 9, 2016 12:35 PM
supersuave89
Nov 7, 2016 10:29 PM
ElanS2
Aug 21, 2009 03:21 PM
dexue
Jun 3, 2005 01:06 AM
