FS: 2009 Fit GE8 OEM Ignition Coil Packs
Old Dec 6, 2018 | 04:50 AM
zenkimr_S's Avatar
For Sale. 3 OEM coil packs from a 2009 Honda Fit GE8. I was having misfiring issues with cylinder #2 so I decided to replace all 4 at the same time. Turns out cylinder #2 spark plug came loose causing the misfire and brunt up the boot on coil pack #2 a little bit (picture added below). I know these are expensive from the dealer, but these might help someone here. These had 132,XXX miles on the car before I replaced them with Denso coil packs. These 3 were working perfectly fine when replaced. Asking $15 each for the working 3 coil packs and are sold as is. Coil pack #2 you can take for free if you purchase the 3 together, but you need to use this on your own risk. I'm just going to throw it away if buyer does not want it. Located in Glendale, CA.
JCLW
Aug 14, 2023 04:41 AM
nickroz
Feb 26, 2017 08:21 PM
Mtwalenciak
Dec 23, 2014 10:04 AM
RomeoJunior
Oct 20, 2014 03:38 PM
dtgrosse
Jul 17, 2014 01:04 PM
