where is radio fuse?
Old Jul 8, 2019 | 09:40 AM
crazyking's Avatar
My cd/radio unit with display stopped working or won't turn on last week. I have been searching around on the location of the fuse and not able to find it. I am wondering if someone can point me to the right direction. My car is 2018 model.
2017-2019 fuse box diagram:
https://www.autogenius.info/honda-fi...e-box-diagram/
Old Jul 8, 2019 | 01:12 PM
Action Jackson's Avatar
It's in the engine bay. 10amp fuse. I followed the diagram under the fuse box lid.
Old Jul 8, 2019 | 02:29 PM
crazyking's Avatar
Thank you Jackon. I will post back if switching to a new fuse solves my problem.
Old Jul 12, 2019 | 07:20 PM
crazyking's Avatar
I checked the owner's manual. It still doesn't say which 10amp fuse is for the audio unit. I then switched all the 10amp fuse around. After each switch, I tried to turn on the car to see if the audio unit works, no luck. Then I concluded it's not a fuse problem. Dropped the car to the dealership and a few hours later got a phone call. The tech didn't find any issues and the audio unit is working perfectly. He also mentioned there is a way to lock the audio unit(other than just powering it off), I have been adviced to press and hold the power button about 10 seconds if this happens again.
Old May 1, 2024 | 04:08 PM
3rdGenOwner's Avatar
I know I’m late to the party, but I had the same issue after accidentally applying reverse voltage when jumping my car. The 15 amp ‘backup main’ fuse in the #21 position in the engine bay fuse box needed to be replaced.
A few systems were out, namely the audio unit, the fob controls, and the automatic dome light.
STOCKTREK
Jul 25, 2011 06:09 AM
Fit of RAGE
Sep 24, 2009 10:32 PM
setter11
Jan 4, 2009 12:46 AM
kyo2529
Oct 2, 2007 01:37 AM
jchav
May 28, 2005 04:41 PM
