HELP! Part falling off engine?!
Help! There is a part falling off the bottom of my 2007 Fit, somewhere between the front tires. (Photo below was taken from passenger side, behind front tire.)
Can anybody tell me (1) what this part is; (2) whether I need to call a tow truck, or if there is a temporary fix that I can do to make this safe to drive in for repairs; and (3) approximately how much it should cost for this repair?
I don't know much about car repairs (obviously!), so I apologize if this isn't quite the right forum. Thank you for any help that you can offer!
(link: http://www.mediafire.com/view/vt2oeu9jkysf333/tmp.jpg)
Sorry, this is my first time posting on a forum. I tried fixing the link in the original post, so hopefully that works now. Here is the pic: http://www.mediafire.com/view/vt2oeu9jkysf333/tmp.jpg
Thanks!
Thanks!
if it's just the shield, then its $25 from bernardi
18181-PWA-J10 | Honda COVER (LOWER) - Bernardi Parts
with a jack or ramps you can do it urself.
if it affected ur catalytic converter then its around $800 part for the part....
did u run over something?
Those shields flex and rust off all by themselves. I'm sure nobody ran over anything...
The difficult thing about replacing them is the rusted bolts. (Those are usually "frozen" in place.)
Recommend removing the shield. (Might have to cut it off, be respectful of the wires to the oxygen sensors!)
I agree. I believe it is a heat shield. It is used to keep the catalytic converter from catching grass the below it on fire when parked. After you remove the shield just do not park over any dry grass or leaves. It should be a simple replacement. Those things are cheap and flimsy. They usually rust and fall off after a number of years.
This exact part was hanging down on my daughter's 2007. It is the heat shield on the bottom side of the catalytic converter. In our situation, one end had corroded enough to disengage the mount and it hung down just as your's did in the picture. The other end was still attached pretty securely. I had to use large tin snips to cut the part off. We never bothered replacing the part, (although at some point I should, to eliminate the combustion potential as n9cv indicated)
go to your local hardware store and pick up 2 hose clamps like these
Amazon.com: 12 in. - Duct Clamps - Worm Drive Fastener - Stainless Steel - Rust Resistant - Sold By Each - UltraGrow UG-FCFP/12: Patio, Lawn & Garden
then just clamp the thing back on and you should be good to go
Duh!!!
Why didn't I think of that?
Thanks. I remember that if it ever happens to one of my Fits.
That is exactly how the heat shields are held on to the mufflers of my motor home. I also have two more heat shields where the exhaust pipe goes by the fuel tanks. Those shields are also held on with the same type of stainless clamps. I just never though of it on the Fit.
GE82010
Aug 22, 2018 03:22 PM
