If you had a $1000 Budget??????
Old Mar 25, 2007 | 07:56 PM
bschurma's Avatar
Originally Posted by 03DSM-RSX
lol, i cant believe some of you neglect the tires for best bang per buck. Its pretty much a night and day difference, more than any intake/header/exhaust combo. Comes with benefits for all aspects of the car.
What do you recommend?
Old Mar 25, 2007 | 08:15 PM
03DSM-RSX's Avatar
Frequent FitFreak Poster
Tirerack has a plethora of reviews from all kinds of tires. Summer tires and all seasons are the ones for your daily drivers. All seasons have a longer life span.
My bro used Pirelli PZero Nero M+S on his supercharged tC and currently running Kumho ASX's on my boosted RSX. Both are catagorized as "Ultra High Performance All season tires". The Pirelli's have a tad bit lower life, but GREAT handling and traction in all conditions, but are pretty pricey.
The current ASX's i'm running have been lasting for so LONG. at least 30k+miles, way more than my stock tires did. Traction is great in all road conditions, especially wet. I've ran these tires at the track over 20+ times with hardly any traction trouble.
Tirerack.com has a lot of tools you can use to pick which tires are best for you and user reviews to help you decide as well
Old Mar 25, 2007 | 08:23 PM
George02's Avatar
yes this is true??? im swapping out my stocks... but still we're talking performance parts
Old Mar 25, 2007 | 11:43 PM
03DSM-RSX's Avatar
so you dont consider tires as part of performance upgrading?
after that, i'd probably get a CAI. its the most streetable mod. Does your wife care for noise? if she's nitpicky about that, then you'd have to rreally consider the header and exhaust part. there are some quiet setups out there.
Old Mar 26, 2007 | 01:34 AM
fithouston's Avatar
i would take at least one buck buy a lottery ticket and see if you can turn that into 25K
if that fails intake exhaust and some 14-16lbs wheels that look great and will perform better
Old Mar 26, 2007 | 05:37 PM
Sport's Avatar
Steelblade,
Don't take my comments and the other comments that agree with me as negative - as some suggest. I'm being realistic, and I'm sure the others are as well. I'm not trying to put you down or burst your bubble, I'm just telling you how it is. If you want significant, noticeable power gains you'll have to look past the generic cookie-cutter Intake/Header/Exhaust modification, because the I/H/E is actually a complimentary modification to what should be done to the engine internally first.
Now, if you're still gung-ho about this idea, please do me a favour. More importantly, do yourself a favour. Before modifying your car, take the car to a shop that has a dyno. Have its stock power checked. It will probably be between 90-95 hp at the wheels. Have them save your profile. Go nuts on your I/H/E swap (don't change anything else). Then, come back to the dyno shop and check your car's power. Superimpose the results with your stock results and see where you've gained/lost power.
Don't forget to post your results here on the forums. I'm more than willing to discuss your situation, especially when I'm proven wrong. And, it should provide FitFreak with a good base information when other people down the road are looking to do the same thing.
PS: It is important to note not to be hung up with peak hp or peak torque numbers. The important thing you need to worry about is did you gain hp/torque in the powerband range where you want it the most, and how much.
Old Mar 26, 2007 | 05:51 PM
fit4kris's Avatar
^^^^ What he said! I think too many people take it as bashing. If I didn't own a Fit, I would say "Sure, maybe that is bashing." But I do own a Fit and have owned cars with 4 times the power as well and turbo's the size of the Fit's engine. It is not going to be anywhere near mind-blowing power with the intake, ex, and header upgrade. It will add some go but you won't get wood from the power.
All I am saying and I am sure others are saying is if you want go-fast power, motor swap and forced induction. That's it.
Good luck.
kris
Old Apr 9, 2007 | 12:01 AM
friends288's Avatar
i agree!! i did so much research on which part i should mod first. at the end i mod the intake. i got the T1R intake, its sweet. theres noticeable difference starting from 3k rpm. when it is near 5k, it just screaming. lol..
like what ben said. T1R intake + T1R 50S Muffler gain 10Hp. i believe if included the b-pipe and header, then is around 20hp.
https://www.fitfreak.net/forums/aj-r...-dyno-2-a.html
the T1R 50S Sport Exhaust System is $600 and T1R B-Max Carbon Intake is $350... total $1000... gain around 13-15 hp.
Old Apr 9, 2007 | 12:13 AM
friends288's Avatar
since i just ordered Work Emotion CR Kai 16x7 bronze w/ 205-45-16 Kumho SPT. so broke, cant do my next mod until 2-3 months later. since i got T1R intake, my next plan is to get Fujitsubo Wagolis muffler (sinec i dont like loud exhaust) . then after get spoon B-pipe. hope the b-pipe wont be that loud. then maybe header, but i doubt it. since the warranty.. i dont know, still have to ask the dealer about the warranty.
what do you guys think? good path?
Old Apr 9, 2007 | 04:49 AM
s0x's Avatar
s0x
ignint
im probably being completely ignorant here but i know back in the 20th century if somone wanted to gain a grip of horsies for a few hundred bux they bought a lightweight flywheel wich can add upwards of (virtual) hp! virtual horsies for those who dont know ( and virtual is probably technically the wrong word but thats what ive allways called it) is horsepower that cannont be dyno'd but the flywheel weighs less therefore your power gets to the wheels easier the end spend 400 bux and even on a tiny car like the fit you may get a significantly noticable difference... feel free to tear what i just said apart as its 2 am and im tired as shiznit!!! but if im right someone gimme some props! also i dont know if anyone makes a lightweight fly for this car but i imagine there is a japanese aftermarket one you could buy and i agree for 1k i would get the flywheel and some new wheels+tires that may be more like 1200 tho
Old Apr 9, 2007 | 04:50 AM
s0x's Avatar
s0x
upwards of 20 i forgot to put 20
Old Apr 9, 2007 | 06:00 PM
  #32
nexus4400's Avatar
I think any type of modification made to a stock car is all about tradeoffs. First off, there is no power to be made since the the volume of air injested is almost the same (nothing to FORCE more air into the engine). For basic bolt-on parts, power is GAINED from trading off another aspect of the vehicle. A nice free flowing intake and exhaust will net a few ponies in expense to added engine/exhaust noise, less mileage, and perhaps driveability. Likewise, a super light weight flywheel will decrease the amount of inertia stored and hence merit to driveability issues. I would recommend a free flowing intake and exhaust if you are ready for added noise. Buck for buck, the amount of HP gained is not substiantial.
Old Apr 9, 2007 | 06:49 PM
  #33
JamesBizzle's Avatar
If you don't like loud exhausts then you might want to consider the Tanabe Concept G or Touring Medalion. They stay under 93db at all RPMs and that's with no silencer.
check them out:
Tanabe Racing Development, USA - Concept G Catback
Tanabe Racing Development, USA - Medalion Touring
Old Apr 9, 2007 | 07:30 PM
  #34
friends288's Avatar
i think Tanabe Concept G or Touring Medalion are louder than Fujitsubo Wagolis
Old Apr 9, 2007 | 07:59 PM
  #35
really!? wow... I haven't heard them one after the other but damn, if the Tanabe's are louder then Fujitsubo Wagolis the Wagolis must be crazy quite... wow. didn't know that.
Old Apr 9, 2007 | 08:10 PM
  #36
friends288's Avatar
i dont know. but thats what people told me. Fujitsubo Wagolis is almost like stock.
Old Apr 9, 2007 | 11:46 PM
  #37
milano sol's Avatar
id say a nice set of GOOD tires, throw in a K&N high flow filter, axle back exhaust and maybe some lowering springs....
-tires should be 400-500 at the most
-springs 120-160
-K&N 50
-leaves you 290 or so on a axle back of your choice
hope this helps....
tires=better braking, accel, decel, cornering
springs=better cornering, possibly better ride, lower center of gravity
K&N=better air flow, slight power gain
axle back=sounds nice and looks better than stock.
Old Apr 10, 2007 | 06:45 PM
  #38
storm88000's Avatar
Originally Posted by Chikubi
The Fit's airbox is very restrictive, mostly for fuel efficency and noise control. Replace it w/ a good intake like a T1R or Power Box and you will not only improve the throttle response and drivability of the engine, but also open it up so that it can better use what power it has under more stressful conditions, like climbing hills, etc. You may take a small hit in MPG, but it'll be offset by not having the engine bog nearly as much when under a heavy load or hard acceleration.
I find this interesting. I was always under the impression that an aftermarket intake (especially a CAI) will improve gas mileage as it makes the engine more efficient overall. Same with an exhaust. The reason that Honda and most of the car manufacturers choose to use such a restrictive airbox is because of the noise - they don't want to turn off potential customers during the test drive (especially women ).
Old Apr 10, 2007 | 07:13 PM
  #39
805FitSport's Avatar
my wago is pretty loud with my full exhaust set up...
Old Apr 10, 2007 | 07:28 PM
  #40
friends288's Avatar
your wago is loud.. um.. i am trying to find one that is quiet ... is Tanabe Medalion Touring the only one/?
