Port n Polish
Old Jun 23, 2007 | 09:16 AM
kusojiji's Avatar
Is there a company that has developed a CNC program for the heads? Port and polish can be disastrous if done incorrectly.
You could end up cutting into a water passage, making the port too big to be effective, create a flow pattern that does not work, create differences between the cylinders thus negating any gains, etc.
CNC'd heads are consistent between cylinders and usually, have a lot of engineering behind the program. Port shape, volume, and flow patterns are taken into account during the programming.
Old Jun 23, 2007 | 01:08 PM
kimo's Avatar
Best are DH-Racing - Import Performance Specialists for port and polish.
Old Jun 28, 2007 | 12:32 PM
biscuitninja's Avatar
QFT! But as for polishing, I don't think too many ill effects will happen from port patching as well as removing flashing and smoothing out the surface. I don't think you'll see HUGE gains though, I feel you'll need better cams for that, but that is a whole other can-o-worms.
-bix
Old Jun 28, 2007 | 08:04 PM
kusojiji's Avatar
Yeah, as long as everything is done in moderation (sounds like a diet, eh?) I've seen many horrors done on heads in the past and would prefer a tried and true system.
If you're just polishing and not removing too much material, then a small increase in CAM specs might help. If you hog out the port, then you may need a bigger CAM to make it useful, but then again, you're going to have to spin some RPMs to make it work. It's a small pump anyway.
jms
Apr 24, 2019 06:18 AM
Alastair_S1D
Jan 9, 2016 04:28 PM
Blackbeard
May 15, 2011 09:25 PM
larshnordli
Jul 19, 2009 07:11 AM
Yehia Tanbouly
Sep 13, 2006 07:40 PM
