jazz/k20
Old Feb 21, 2006 | 01:58 AM
  #41
ekek888's Avatar
the motor can be installed either way but to install from top, the rad upper mount will be converted from being spot welded to bolt on .
Old Feb 21, 2006 | 02:14 AM
  #42
ICantFit's Avatar
how much did the whole project cost in PESOS?just wonderin?
Old Feb 21, 2006 | 05:57 AM
  #43
ekek888's Avatar
Cool
good question. i stopped counting after six months working on it. its like the movie "money pit"
Old Feb 21, 2006 | 09:33 PM
  #44
ICantFit's Avatar
Question
thought so too..but how much would it cost for the engine and the front suspension of the dc?..sa autoplus ba ginawa to?how long did the build last?
Old Feb 22, 2006 | 04:21 PM
  #45
ekek888's Avatar
made it in my shop with my tinsmith and a mechanic. the half cut DC5 cost USD$5k. most was installed in the jazz, i also had to buy the LHD DC5 steering rack.
if i were to do a similar swap, it will probably take 3 months.
Old Feb 22, 2006 | 09:06 PM
  #46
ICantFit's Avatar
WOW!!! deep pocket eyy...the engine itself cost as much as a second hand EG hatchback..I'll probably build one of those with a b20 block paired with a b16 head..less buck for almost the same bang...tnx fro the info bro!
Old Feb 23, 2006 | 12:01 PM
  #47
Gioujazzgr's Avatar
where you find turbo kit for Jazz?
Old Feb 23, 2006 | 01:48 PM
  #48
dougiepants's Avatar
Avid FitFreak Poster
Seems to me this whole thing might become easier once the mounts from Hasport and articles are out for it
Old Mar 2, 2006 | 12:23 AM
  #49
tommyafrica's Avatar
hey ek888 ...you sure are nuts .that takes a lot of time and fabrication
but that is pretty extreme mods .who is doing the work is it yourself
Old Mar 2, 2006 | 10:15 AM
  #50
It is him that I know of.
Old Mar 5, 2006 | 07:19 PM
  #51
blacksirek's Avatar
True said but where the b20 n/a tops out thats where the k20 begins. K-series is the way to go. Expensive but just do it yourself. It doesn't seem that bad.
Old Mar 5, 2006 | 07:21 PM
  #52
blacksirek's Avatar
Bye the way, is it possible to use the DC5 rear brake assembly and spindles(entire brakes) on the fit. Or just only dc, eg, ek stuff. I know that the DC5 brakes just bolt on right?
Old Mar 9, 2006 | 09:10 AM
  #53
ekek888's Avatar
its not bolt on. have to machine an adaptor.
Old Mar 9, 2006 | 01:45 PM
  #54
doesn't seem like it would be that big of a deal. but spacing issues might be caused by using that.......
Old Mar 9, 2006 | 01:49 PM
  #55
Halo's Avatar
Originally Posted by spoonfit
dont call you mom, just call me and i will put her on the phone
Can someone please ban this moron
Old Mar 11, 2006 | 12:08 PM
  #56
blacksirek's Avatar
Thanks for the info. I know that the DC5 suspension is a bitch interms of weight. Everything thats off the RSX/Integras is heavy and built really strong. Did you weigh your car on a scale before and after? If so, what was your previous stock weight (curb weight) and the current weight (with suspension, motor, subframe etc,)?
Old Mar 11, 2006 | 04:48 PM
  #57
ekek888's Avatar
not really. i know that its heavier than a stock jazz specially now that i have a 120lbs sound system at the back.
Old Mar 11, 2006 | 11:09 PM
  #58
Cleareance issues and does it push the rear wheels out further to the quarters?
Old Mar 11, 2006 | 11:50 PM
  #59
ekek888's Avatar
the width of the mounting plate each is 50mm and will approximate the dc5 rear track.
i had to enlarge the wheel well considerably, if u will notice, the rear doors edges is the circumference of the wheel opening. we removed about 50mm of body metal there
Old Mar 12, 2006 | 08:29 PM
  #60
That is just crazy.... I hope once the NA models come out it will help get this swap done easier.
