exhaust fitting
Yes, as long as the axle back is for a GD and the rest of your exhaust is factory or bent in the factory positons, they will be swapable. The only way they won't is if you try to use the axle back portion of a cat back (say Skunk2 or Invidia) with your OEM B-pipe since the cat back is designed only to work with as a complete unit by that manufacture.
Any time.
If you would like to see a more detailed response regarding the complete break down on GD exhaust components please click the link below.
https://www.fitfreak.net/forums/1st-...tml#post912055
If you would like to see a more detailed response regarding the complete break down on GD exhaust components please click the link below.https://www.fitfreak.net/forums/1st-...tml#post912055
SikxChoi
Mar 13, 2012 03:13 AM
George02
Mar 20, 2007 03:06 PM
