painting the fog lights housing
Old Sep 8, 2008 | 07:07 PM
alexfree05's Avatar
I am thinking to paint the fog light housings to flat black tomorrow.
When painting the fog lights housing, do I need to remove the front bumper?
do you sand the housing before painting it?
Thanks!
Old Sep 8, 2008 | 08:12 PM
El Chupacabura's Avatar
I did this like 2 months ago it was real easy. If you look in your instruction book it will tell you how take off ONLY the fog light covers there is a little screw on the inner area near the radiator. Sand the covers with something light like 800 grit sand paper and use Krylon Camoflauge black paint to paint it. I't at school right now but ill post pics when i get home.
oh btw, the search box is your friend , here is a thread on how to remove the fog light covers.
https://www.fitfreak.net/forums/fit-lighting/6982-yellow-fog-light-vinyl-film-installation-questions-answers.html
Old Sep 8, 2008 | 08:36 PM
alexfree05's Avatar
Thanks man!
but the link is not working =]
Old Sep 8, 2008 | 10:06 PM
ds62987's Avatar
I just took my foglights out yesterday to put the lamin-x on. It's real easy just take out the screw that connects from the lower grill area towards the foglight housing and the whole housing will slide out. after that there are two screws that hold the foglight in the foglight housing. I'll find the link to the instructions real quick hope this helps...
Old Sep 8, 2008 | 10:09 PM
ds62987's Avatar
This is a sticky in the lighting section of the forums if the link doesn't work...
https://www.fitfreak.net/forums/fit-...s-answers.html
Old Sep 9, 2008 | 12:16 AM
alexfree05's Avatar
i got you=]
thanks a lot
Old Sep 9, 2008 | 01:21 PM
^^ hey no fair!! Thats the page I tried o link to. I guess i just suck at linking lol.
To paint my fog light covers I used Krylon Flat black camoflauge paint. It was kinda hard to find but I found it at my local Pep Boys, I dont know if those exist in indiana though... I cant really remember but I sanded the covers first with either 800 or 600 grit sandpaper, just enough to rough it up so the paint will stick. After I put about 4 coats of paint on each cover and let them dry for 3-4 hours. It's easy to do and it makes the car look a lot better.
Old Sep 10, 2008 | 12:55 AM
isthata_scion's Avatar
yeah did mine not too long ago. used a fine grade sandpaper and duplicolor black bumper coating spray paint found @autozone. whatever you do dont rush it!
Old Sep 10, 2008 | 12:01 PM
mikow's Avatar
yes you have to take out the bumper. no you dont have to sand. just primer, base paint, and some clear coat.
Old Sep 10, 2008 | 02:11 PM
alexfree05's Avatar
i changed the fog light bulb yesterday, I havent remover the bumper
but i got no time to paint it =[
will paint it on the weekend =]
Old Sep 10, 2008 | 02:16 PM
JDMchris.com's Avatar
I run THIS
hahaha.... you dont have to remove the bumper. There is 1 screw that holds the housing on the bumper. You unscrew that, unplug the harness, remove the screw on the back of the housing and that frees the housing from the lens. Then sand, just enough to scuff the paint so the paint adheres to it correctly. Then primer, then black.... Clear if you choose. I did 2 primer coats and about 5 black coats and no clear.
Old Sep 10, 2008 | 02:51 PM
singlecam screamer's Avatar
Yeah i'm with Chris , i did mine in like 30 mins. i used adhesion promoter and 5 coats of paint. Good luck man
Old Sep 10, 2008 | 04:14 PM
Hey chris, I never noticed that you have the EDM front end on your fit. Did you just put it on or was it always like that? I like it way more than the USDM bumper. *thumbs up*
Old Sep 10, 2008 | 04:23 PM
I run THIS
been like that since may.
Mr08FiT
Sep 21, 2009 09:01 PM
caie-u
Mar 20, 2008 08:36 PM
Hondasforlife
Feb 29, 2008 11:48 PM
dbcmaster
Nov 28, 2007 01:56 PM
joshua27
Sep 9, 2007 02:03 PM
