Hood Damper on CF hood?
Old Oct 3, 2014 | 03:58 AM
s0x's Avatar
s0x
Im looking into getting hood dampers for my new CF hood but the ones that i have seen on ebay as well as the ones from password jdm and NRG say you can't use them on cf. does anyone know why and is there any company that makes a cf friendly hood damper?
Old Oct 3, 2014 | 05:20 AM
derykisonder's Avatar
From what I remember there's two types of nrg hood dampers. One is polish and the other is carbon. The Polish is for oem hood and the carbon is only meant for carbon hoods.
Old Oct 3, 2014 | 03:24 PM
07hatchfit's Avatar
you can put any type of damper on a CF hood
07hatchfit's Avatar
Ive done both
Old Oct 3, 2014 | 03:48 PM
s0x's Avatar
s0x
Originally Posted by 07hatchfit
Ive done both
can you tell my why it says not to? are the stock mounting points deleted or is it just to much force?
Old Oct 3, 2014 | 04:05 PM
Waiz's Avatar
Avid FitFreak Poster
Moved the thread for you to the correct location from the marketplace
Let me know if your question is for a GD or GE
Old Oct 3, 2014 | 04:19 PM
s0x's Avatar
s0x
thanks! its for a gd3
Old Oct 4, 2014 | 02:18 AM
DWils's Avatar
I have a T1R damper (just one) for my GD. It says nothing about using it or not on carbon fiber hoods here: Type One Racing :: Engine :: Fit/Jazz (GD3/4) :: T1R Engine Hood Damper - Honda Fit 07-08 GD3. I have seen other members (previc93 for one) who has a carbon fiber hood and a damper but I don't know which brand damper they are using. I think the "Don't use this with a carbon fiber hood" warning is for some sort of liability in that it "might" be possible to bend the hood if you're not careful when shutting the hood. Kind of like the FlashPro is for "Off-road use only" just as HID conversions, etc.
Old Oct 4, 2014 | 04:47 AM
s0x's Avatar
s0x
How is the fitment with the t1r Kit? Easy install? Would you buy it again?
Old Oct 4, 2014 | 05:39 AM
DWils's Avatar
Good, I guess. Yes. Yes.
The bottom portion of the damper attaches to a bolt on the headlamp assembly (it makes sense if you look at the aforementioned link). I had a problem with the tube (the black part, not the silver part) hitting my fuse box. To rectify this I sourced a longer bolt from who-knows-where of 10+ years of Hondas that I've tinkered with and some washers to raise the bolt platform so that the angles would work such that the tube didn't hit the fuse box anymore. The damper also comes with another hinge for the hood. I was able to install everything myself with little inconvenience. I would give it a 3 out of 5. All you need is some metric sockets, a wrench, and about an hour or so. Probably less, and everything bolts right up. I've had it for about 2 years (give or take) and I have not had any problems with it. It stays up by itself, so no need for a clip or a lock or something to make sure it stays open.
Old Oct 5, 2014 | 05:01 AM
s0x's Avatar
s0x
awesome thanks ill probably order one this week!
Old Oct 5, 2014 | 04:53 PM
DWils's Avatar
Glad I could help. There should be a few other hood damper threads hanging around if you want to check those out for any more information before you make your purchase. No matter which damper you go with I'm sure you'll like it. I found random reasons to look under the hood just so I could open it and use the damper. I'm easily amused amd like the sound it makes when it opens.
Old Oct 6, 2014 | 10:28 PM
s0x's Avatar
s0x
oh snap so i was about to order this from AJ racing but they want 40 bucks for shipping BOOOOO! anyways i just realized do you think this will still work with the password JDM battery relocation kit?or will that get in the way? does it mostly just hover over the fuse box or is it kind of in between the two? Also what exactly does the engine pay side of the damper mount to?
thanks again for all your help.
Old Oct 7, 2014 | 04:53 AM
DWils's Avatar
They better be buying you dinner for $40 in shipping! I hate outrageous shipping charges because it really only costs $10 to ship yet you get charged for $40. I don't know anything about and have never seen the battery relocation kit, so I can't say if it will interfere with it or not. My guess is that it will not interfere or cause any problems. The damper tube hovers over the fuse box and does not go over the battery. The pictures in the link are a great example of what it looks like. I don't know what you mean by your last question.
Old Oct 7, 2014 | 02:30 PM
s0x's Avatar
s0x
thanks also the last question.... what in the engine bay ( not the side that mounts to the hood) is the damper mounted to? the headlight? the frame?
Old Oct 7, 2014 | 09:46 PM
DWils's Avatar
Both, kind of. It uses an existing bolt from the top part (the part closest to the windshield) of the headlight. The damper base also slides into part of the frame to keep it from twisting left/right. It's kind of hard to explain, but the picture depicts it and you'll figure it out when you get the damper.
Old Oct 7, 2014 | 10:09 PM
s0x's Avatar
s0x
I'm just wondering if it will fit onto a JDM headlight. I'm assuming probably yes though.
Old Oct 8, 2014 | 07:28 AM
DWils's Avatar
Measure the distance from the bolt hole I talked about and the next hole in the frame of the inside of the fender as you go towards the windshield. If the distance is a smidge over 4in then it will work.
Old Aug 8, 2015 | 08:29 PM
DWils's Avatar
How'd everything turn out?
blackndecker
Jul 24, 2010 10:46 AM
Cat
May 9, 2010 12:59 PM
taFITta_sport
Sep 28, 2009 05:45 PM
i-Fit
Jun 26, 2007 10:57 AM
Jimmy101
Jan 13, 2007 02:19 PM
