Tire size needed for a 2010 Honda fit with 15 inch alloy wheels it now has 185 60-15,
Tire size, can I go to a 195 65-15 tire on a 2010 Honda fit with 15 inch alloy wheels, it now has 185 60 15 on it
Your stock size is either 175/65-15 or 185/55-16. Use any tire size comparison website to figure out what you should put on there to either 1) find a compatible size for the stock size or 2) find a comparable size for the diameter you are currently running.
https://tiresize.com/calculator/
The size you are looking to install would add an inch to the original/stock diameter.
