new guy need help ( of course) with transmission 2015 3rd gen
Old Mar 18, 2021 | 02:09 PM
fitwits's Avatar
Hi New to forum i have owned anew 2016 and used 2015. I am reaching out for help from fit freak because I was replacing lower transmission stabilizer because of the wayward tree trunk during a flash flood. I thought that only the mechanism and bracket had been damaged after further inspection I realized that the bolts that held the bracket had caused the aluminum Housing to crack There is a small amount of transmission fluid very minuscule but enough to notice I was curious if anybody had a quick fix sort of like aluma seal . or JB Weld ? In addition I would like to find out if anybody has replaced this housing )I found one for $50) delivered and what I would be getting into mechanically. it looks like I might have to remove the CV joint. any insight would be greatly appreciated thanks
azopelnut
Jul 7, 2017 02:02 PM
danlisahall@comcast.net
Feb 20, 2017 06:33 PM
Fit Pal
Mar 14, 2016 04:00 PM
rylees
Jan 15, 2014 01:02 PM
phenoyz
Dec 11, 2013 07:26 PM
