Bluebatmobile Overlays Ready
Old Apr 5, 2008 | 02:03 PM
Kelmar's Avatar
Frequent FitFreak Poster
Exclamation Bluebatmobile Overlays Ready
Just thought you guys would like to know. Bluebatmobile has his gallery up along with prices for overlays, including foglights, headlights and taillights, for the '07-'08 Fit!
BlueBatmobile2005/Honda Fit Overlays - Photobucket - Video and Image Hosting
Email him at bluebatmobile@san.rr.com
Old Apr 5, 2008 | 03:29 PM
kptrulee's Avatar
emailed him
hopefully get my order placed soon
Old Apr 5, 2008 | 03:41 PM
Kelmar's Avatar
Be sure to post up if you like it or need any help.
My best advice is to use a hairdryer.
Old Apr 9, 2008 | 01:05 PM
aliencowboy's Avatar
I just installed a set, they look great.
Here are a few pics.
Old Apr 9, 2008 | 08:12 PM
Kelmar's Avatar
Looks great! What were your impressions on the process?
Old Apr 9, 2008 | 08:17 PM
smatts's Avatar
Honda Fit Forums Moderator
I want to see pictures of the smoked and amber overlays for the fog lights.
Old Apr 9, 2008 | 08:19 PM
Kelmar's Avatar
I'll email him and see if he's sold any. I can always photoshop something if you'd like.
Old Apr 9, 2008 | 10:21 PM
I used a hair dryer to warm the overlays up and it took about 30 minutes total for both lights. Very easy to do.
Old Apr 10, 2008 | 12:42 AM
SD_MR_FIT's Avatar
i used VERY little water, and i used my thumbs to get the water out. and i basically stood infront of my heaters in my car to let it dry super quick.
its basically like tint, so if you let it dry, your SCREWED. unlike lamin-x you can repeal and start all over.
super easy , took me about 15 mins for both lights. at first i couldnt get the water out...but then i found the neat trick with my thumbs.
just start on 1 corner and just work your way diagnal to the other corner. that was the best way for me.
Old Apr 10, 2008 | 12:43 AM
SD_MR_FIT's Avatar
i think next time, i wont even use water. i think i could hit the tint straight on...
ill let you know how my headlights and rear tails go.
Old Apr 10, 2008 | 10:18 AM
Arisenfury's Avatar
Anyone have some full-car pictures with the smoked tail lights? I haven't been all that happy with my LED knock-offs as of late and I figure it'd be pretty easy to smoke my stock tail lights since they're not mounted on the car but none of these pictures really show how it looks on the car.
Preferably on a VBP
Old Apr 10, 2008 | 10:20 AM
Arisenfury's Avatar
Nevermind I found some on that link. Although I would still be in for a pic on a VBP.
Old Apr 10, 2008 | 12:14 PM
Kelmar's Avatar
Will, I can get larger pics of the smoked tails on an SSM if you'd like. I've got the smoked tails with the reverse cutout so that it stays clear (obviously an option of course).
I'm headed out of town but I'll be more then happy to take more pics when I get back if you'd like.
Old Apr 10, 2008 | 04:39 PM
Arisenfury's Avatar
Sure that'd be awesome! Good luck at the wedding too .
Old Apr 16, 2008 | 06:07 PM
ASquared150's Avatar
Help! got mine... i think, for the tail's it came in four pieces and no instructions as to wear these pieces fit. They don't particularly line up to anything either... i think he sent me the wrong ones.
Old Apr 16, 2008 | 07:12 PM
Kelmar's Avatar
Do you have pics of what you have? Last I heard it was only a two piece model.
Old Apr 16, 2008 | 07:13 PM
Kelmar's Avatar
Any angle or anything in particular? Close up, far away, etc?
Old Apr 16, 2008 | 07:23 PM
i believe the problem is that i am trying to fit these to aftermarkets. the contours on them are just the slightest bit different, and the part of the stock tail that juts out for the reverse lamps is not present.
either way, i'm trying to simply use the top piece of the two pieces to cover only the white of the tail light, but the lines don't match up - any suggestions, i figured i'd put it on and cut to fit as i apply it - seems risky though...
Old Apr 16, 2008 | 07:30 PM
Kelmar's Avatar
If what you are doing is what I think you are doing then trimming it should work fine. He sends his overlays larger then needed so they don't have to be lined up perfect and can be trimmed.
I know when I did mine (stock tails - 2 pieces per light), a little bit of trimming needed to make the bend at the contour.
I'd suggest either tracing the curve of the white section onto a piece of paper and trimming with the paper as the guide. HOWEVER, it would probably be easier to put them on and trim them to the proper size after they are on the car (I'd suggest an exacto knife).
Old Apr 16, 2008 | 08:09 PM
That's what i was thinking would be easiest. Do you think i should just apply the entire sheet and once it sets cut off what little bit hangs over onto the red of the light? Or Cut while they are setting?
