Any GE8s Running HIDs?
Old Oct 29, 2008 | 01:53 PM
reako's Avatar
Originally Posted by strmslvrfit
the kit is 6000k
Can you post a link to where we can purchase the kit? How much was it, and how easy a job is it to DIY? Thanks!
Old Oct 29, 2008 | 02:00 PM
JDMxGE8's Avatar
www.xenonvisions.com
Old Nov 10, 2008 | 05:34 PM
713_fit's Avatar
so ifi get KID I have to disable the DRL??
which bulb is the DRL LIGHT??
or is DRL the same as high beam?
Old Nov 10, 2008 | 05:37 PM
JDMxGE8's Avatar
DRL is the same bulb as the high/low beam.
Old Nov 10, 2008 | 06:46 PM
neteng101's Avatar
Any pictures of where you ended up mounting the ballasts?
Old Nov 21, 2008 | 01:38 PM
OhNineFIT's Avatar
where can i get HID 6k for my GE? the 09 fits are running on Bis right?
Old Nov 21, 2008 | 01:54 PM
JDMxGE8's Avatar
https://www.fitfreak.net/forums/gaug...onvisions.html
^ Xenon Visions Group Buy.
Yes, GE8s use bi-xenons.
Old Dec 7, 2008 | 11:08 PM
bryanfor311's Avatar
any chance of a small install tutorial, or even a list of steps to get them installed. I believe I wanna give these a shot!!
Old Dec 8, 2008 | 01:54 PM
Speedee 09 Fit's Avatar
I have a kit on order for my GE from Xenith Xenons. I will try and do a tutorial when I get them.
Old Dec 11, 2008 | 10:34 AM
OhNineFIT's Avatar
can't wait!
Old Jan 16, 2009 | 10:15 AM
ratedz's Avatar
I ordered a 6000k bi-xenon kit from Xenith Xenons for my '09 and got it yesterday and got it installed last night. The install was fairly easy...the most difficult part was finding a spot to mount the ballasts and the relay, and even that wasn't too tough. I still need to clean up the wiring, but they are installed and working and they look great!
Old Jan 16, 2009 | 01:44 PM
  #32
Alpha Zero's Avatar
Best place to mount the ballast is right under the headlights.
Old Jan 16, 2009 | 08:09 PM
  #33
JDM_DOHC_SiR's Avatar
I found a good place to mount the Relay in a place that looks like it came from the factory that way...... I get my new camera tommorow.. so I`ll try to take some pictures then.
Old Jan 20, 2009 | 03:01 PM
  #34
txmatt's Avatar
Is this the high beams? The cutoff makes it look like it's low beams, but that sure is a lot of light on the pickup's rear window and lighting the pink flowers on the right.
Old Feb 25, 2009 | 10:16 PM
  #35
jeremi84's Avatar
hey can you please post a pic showing where you install the ballast? i installed them near the battery but im guessing there might be even a better place?
i have 6000k HID also i replace the parking light as LED
Old Jul 4, 2009 | 02:11 PM
  #36
Fitcious's Avatar
if I install HID on a fit, will it blind the person in front of me? It seems like it will.
Old Jul 9, 2009 | 04:45 PM
  #37
whtftspt's Avatar
I just wanted to let you know that I am running hid's and I have my DRL's still working no problem. They are just the dual filliment bulbs. They were pnp right out of the box. I don't have any problems with them messing with anything! I like to have kept the DRL's so I did!!
Old Sep 18, 2009 | 02:30 AM
  #38
Marsbars's Avatar
What HID kit did you get?
Old Sep 21, 2009 | 11:18 PM
  #39
shane's Avatar
good info here..
looks like i just need to pull the DRL fuse(like i did in my g8) and get a hi low h4 HId kit
DK_FIT
May 25, 2009 07:19 PM
Kaotic Lazagna
Apr 13, 2009 02:00 AM
Luichenwai
Oct 25, 2008 12:15 AM
pwnstar
Oct 3, 2008 09:37 PM
c_mack9
Aug 11, 2008 07:06 PM
