HID wiring help
Old Jan 4, 2009 | 03:05 PM
1990hondahf's Avatar
HID wiring help
Just got my kit and have two red and one black from the kit and red/red, red black, and red/white from the car's harness. any idea what the harness colors go to? Thanks!
Old Jan 4, 2009 | 03:23 PM
Super Mario's Avatar
Old Jan 4, 2009 | 04:03 PM
your pics show two black and one red.... i have two red and one black...
Old Jan 4, 2009 | 04:09 PM
it would be helpful if i knew which one was the common(black)
Old Jan 4, 2009 | 04:54 PM
Can you take pics of yours? Might be more helpful if we can see what you're working with. If in doubt try different combinations and you'll know which is which.
Old Jan 4, 2009 | 05:22 PM
here is what i have tried:
picture the car harness looking like this 1 3
The highs work when I connect the (common)black to 1 and the red to 3 OR the black(common) to 3 and the red to 1...i guess polarity is not an issue.
the LOWS ONLY work when black(common) is 2 and the red is 3. Will NOT work when I switch them.
I'm starting the think that the manufacture mixed the wires around....cause this makes no sense to me. If that's the case, it should be like this:
1. common
2 hid low
3 high beam
...does any of this make sense or did i have too many "special" brownies today....
Old Jan 5, 2009 | 10:20 AM
ReeSpeed's Avatar
did you get a bixenon kit?
Old Jan 5, 2009 | 10:43 PM
azncarbos's Avatar
try the red on top and the black/red on the left and then black/white on the right....if still not working switch around the black/red to right and the black/white to the left..... if not pm me....
topvar
Oct 30, 2009 07:51 PM
