?uestion about HID kits
Can you take any temperature bulb and plug them into any HID kit as long as the amperage/wattage/voltage/whateverage are correct? Or is the ignitor specific to those bulbs?
Also, The HID kit I have has OEM style bulbs (H4?) on them, but if I were to do a retrofit, could I take different bulbs that would fit my projectors and just plug those right in? |
You would need get an adapter for the different sized bulbs. The connection is different for every bulb.
Where could I get one of these adapters?
If you are to use a projector that fits on a D2S bulb and use your current ballast you would need an amp connectors you can get it from this site The Retrofit Source (U.S.) - HID Projector Retrofit Kits, Retrofit and HID Componenents, Projectors Lens, Wiring Harnesses, Shrouds and more!
