DIY: Honda LED Roof Light
Old Jan 26, 2011 | 12:15 AM
flip619's Avatar
Lightbulb DIY: Honda LED Roof Light
JDM Honda Fits have the option of an OEM LED dome light, which include the usual white flood light, a single-bulb map "spot" light, and a "fancy" option that lights up a soft blue the four corners of the lamp, all powered by LEDs. Today I installed it in my Fit, and despite no instructions (even in Japanese), I got it to work perfectly in half an hour. Here's how I did it...
The part number for the light assembly is 08E13-E81-010. Not like it will help at the local dealer; I ordered mine from japanparts.com. This is what I got:
The main light is powered by 6 LEDs that light up the reflective surface, creating a relatively uniform light throughout. The spot light is in the center, and the fancy lights are embedded in the bezel on the rear side.
Included hardware should include a mounting bracket, two screw brackets, two screws, two washers, and a ground wire.
First, pry out the lens of the old dome light
Remove and save the two screws
Disconnect the old light
Now for the new setup, take the mounting bracket (where the small tab on the inside is cabin-side) and insert the screw brackets, with the outward bend to the rear, and sandwiching the washers on the near side
Take the grounding wire and stick the pin into the empty slot in the connector
Install the mounting bracket using the old screws, sandwiching the ground wire between the existing mount and the new bracket
Note that if the little tab sticking down is on the left side, the light will subsequently mount with the switches toward the front of the vehicle.
Now connect the LED roof light, test to make sure it works, then screw it in and put on the lens
Here's how the dome light looks. It's freakin bright
and that's during the daytime
This is what the spotlight looks like
And the "fancy" light
To be honest, I was impressed at the brightness and uniformity of the main light, but equally underwhelmed at the dimness of the "fancy" lights. But I guess that's the tradeoff for taking up only 0.1 W (compared to the main light's 4.1 W), and being able to practically leave it on all night without much effect on the battery. Was it all worth just over $200 for the item and shipping? Probably not, but it is unique to be found this side of the pond =P
Old Jan 26, 2011 | 12:31 AM
circa40's Avatar
Oh man, I've been trying to get this (for less) for a while now. Thanks for the install pics and review!
Old Jan 26, 2011 | 12:42 AM
RedlineFit's Avatar
i like that "fancy" light
Old Jan 26, 2011 | 12:52 AM
Fit4Trav's Avatar
very nice.
Old Jan 27, 2011 | 02:17 AM
NiChRiS's Avatar
Nice and classy. looks great
Old Jan 28, 2011 | 07:25 PM
Tauwolf's Avatar
Ok, so here's a question for you: could this unit be opened up and modded for more a impressive "fancy" effect?
I have been letting a "ceiling indirect lighting" installation project simmer in my brain for the past couple of weeks, but then I came across this fancy unit and if it'll save me some blood sweat and tears I may just go with this.
Old Jan 28, 2011 | 07:30 PM
flip619's Avatar
I don't see why not, but good luck trying to get inside o_O
Old Jan 28, 2011 | 07:48 PM
Tauwolf's Avatar
Yeah that's what I'm wondering about. Is it easily taken apart? Sounds like the answer is no.
Old Feb 15, 2011 | 05:09 PM
D50boy's Avatar
Any idea if this would work in a GD3?
Old Feb 16, 2011 | 01:13 AM
flip619's Avatar
According to Honda, yes it is compatible with the GD model
Old Feb 16, 2011 | 04:40 AM
Black3sr's Avatar
$200?? I will use a Dollar store flashlight thank you.
Old Oct 14, 2011 | 10:39 AM
FitStir's Avatar
Thumbs up
Great job!!! +reps
I also saw it on japanparts a while ago, and am still contemplating it, but it looks sooooo nice.
Old Nov 7, 2013 | 02:26 PM
luismycorreo's Avatar
I'm interested, but until now the price is still $200, anyway, i share this video from YOUTUBE from fitfans.br
Luis
Old Nov 7, 2013 | 02:39 PM
FitStir's Avatar
Originally Posted by luismycorreo
I'm interested, but until now the price is still $200, .....
Here's it's a little less expensive... 08E13-E81-010 - OEM Search by Amayama Trading - Amayama Trading
I got the Plasmacluster Honda Access one from rakuten for under $200 also (not including shipping/forwarding).
Old Nov 7, 2013 | 03:20 PM
Thanks for the information, i found on RAKUTEN $115 average (we must use the forwarding service to NA), then i found on AMAZON.CO.JP the seller doesn't ship outside JAPAN, the website you gave me have almost the same price as japanparts before shiping cost i think will cost almost $200.
Luis
Old Nov 7, 2013 | 03:32 PM
FitStir's Avatar
Buy it from rakuten, and ship it to tenso then. It will come out cheaper... ya gotta compare and see what's best for you.
Old Nov 9, 2013 | 09:33 AM
GinoLicious's Avatar
This part number provided, does it work in a GD3? Looks really cool. Would not mind installing in my 2007 Fit.
Old Nov 9, 2013 | 10:32 AM
Sure, I posted a youtube video from finfans.br (the brazilian club) it shows the installation in a GD3
Luis
Old Nov 9, 2013 | 10:39 AM
Sweet! Thanks for the quick reply. Looks like ill be ordering it from Rakuten soon when a Tenso shipping sale comes up haha. Looks like a sick mod that wont take too long or cost a lot of money. Opening the door and having a bright dome light will be nice haha.
Old Nov 9, 2013 | 10:48 AM
Go to this page search for the part number, one of the sellers is DESIR DE VIVRE talk to him and try to arrange the price + shipping, i think you can pay using paypal, I have read good comments about that seller here in other post.
Disclaimer: I do not recommend this seller i'm just sharing the information.
