GE8 DIY Guildeline - Illuminated Auto Folding Side Mirror Switch Conversion
https://c2.staticflickr.com/6/5338/1...6fa3bfd3_z.jpg
*Disclaimer: I'm 100% sure be NOT endorse, recommend, encourage or take any responsibility for the outcome result of someone else doing this conversion. Your conversion at your own risk!* If you insists for conversion means you're AGREED the disclaimer as above. These was done by me on my JAZZ GE8. It should be suitable for USDM JAZZ or FIT... Please follow the guideline on below comment step by step: 1. Remove meter hood https://c2.staticflickr.com/8/7771/1...a2ec4223_m.jpg 2. Remove 2pcs screws https://c2.staticflickr.com/8/7758/1...1f75b61266.jpg 3. Left=Jazz/Fit switch, Right=CRZ switch https://c2.staticflickr.com/6/5465/1...d6bb7603_m.jpg 4. Remove the claws as show by red arrow to separate the switch from cover https://c2.staticflickr.com/6/5451/1...2e08f616_z.jpg 5. Position of claws which can find on top & bottom https://c2.staticflickr.com/6/5443/1...b8317a520a.jpg 6. Switch separated from cover https://c1.staticflickr.com/9/8893/1...385203fb0c.jpg 7. Front View : Left=CRZ switch, Right=Jazz/Fit switch https://c2.staticflickr.com/6/5468/1...12f5a9a84e.jpg 8. Rear View : Left=CRZ switch, Right=Jazz/Fit switch https://c2.staticflickr.com/8/7682/1...8507201715.jpg 9. Create a power cord, earth wire & illumination wire https://c1.staticflickr.com/9/8831/1...1e2792e1_z.jpg 10. Interleave to the socket terminal, red arrow is illumination wire, blue arrow is earth wire https://c1.staticflickr.com/9/8892/1...16295a62_z.jpg 11. Diagram of socket terminal, Pin 10 is illumination wire, Pin2 is earth wire https://c1.staticflickr.com/9/8730/1...84a94c00_m.jpg 12. Wedge the illumination wire to any illuminator line such as VSA or ECON from Power Fuse Box, the earth wire connecting to the Addiotional Ground. https://c1.staticflickr.com/9/8887/1...2b36b712a6.jpg 13. Enjoy the illuminated Auto Folding Side Mirror Switch https://c1.staticflickr.com/9/8826/1...1e4aca88a2.jpg |
