Where to hide huge crossovers!
I have 2 sets of Boston pro60SE one set for the front doors, one set for the back doors, and a kenwood xr-4s to power them.. (kenwood 6960 hu)
The pro60's come with giant crossovers, in fact the 4 crossovers (combined) are the same size as the kenwood 4 channel amp! i'm at a loss on where to put the crossovers. is there room in the doors? I'm planning on building a spare tire subwoofer box leaving the spare tire intact,, and there's going to be 2 amps in there already.. I'd really like to find somewhere else to hide the crossovers. |
I would do everything you can to keep them out of the doors since moisture will be a problem. I stuffed the Hetrz three way crossovers up under the dash, one under the drivers side and one up under beside the glove box. You do have one more option of behind the rear side panel on the passenger side. I think the driver side may be too tight with the gas filler neck in the way.
Feel free to look into the pics of my sub install for ideas on the sub in the spare. |
Mine are under the dash on each side of the car, there is plenty of room there and if you are using the factory locations for tweeters then you are only using 1 set of wires through the door.
Originally Posted by lashlee
(Post 1025393)
Originally Posted by Fit4Spl
(Post 1025400)
Originally Posted by bionicjay
(Post 1025407)
Thats a real nice stealth install for your sub.. you tossed out the spare tire though right?
