Finialized Fit Sheet Metal Manifold..
Old Jan 22, 2009 | 06:15 PM
WRLEO's Avatar
Sorry for the Long delay..
For USDM model Honda Fits..
After 6 months of testing and finalizations, we have come up with a solution to the LOW EGR flow problems with out first batch of Intake Manifolds..
Anyone who has purchased it before the new model, please contact us and we will exchange your old model for the new model..
Here are the pictures of the changes we made to the manifold flange to fix the LOW EGR FLOW problem.
The EGR gases going into the cylinder head were previously blocked off, in our JDM version. The JDM cars dont monitor EGR flow and dont have this problem. Now we allow the EGR flow to flow exactly the same as stock.
Here is the pictures of the Completed Manifold:
Old Jan 22, 2009 | 06:25 PM
Fitcapo's Avatar
Neato can't wait to hear some results from some hopefully satisfied customers.
Old Jan 22, 2009 | 11:10 PM
kylerwho's Avatar
spoon fed
so what is the price of this new manifold?
Old Jan 22, 2009 | 11:18 PM
Kyle is raaddd's Avatar
Master FitFaker. CHEA!
nicee!!!!!!!!!!
Old Jan 22, 2009 | 11:40 PM
WRLEO's Avatar
Price didnt change...
Old Jan 22, 2009 | 11:41 PM
kelsodeez's Avatar
UNBANABLE
i want this, but i dont want to have to get another tune.
Old Jan 22, 2009 | 11:45 PM
kylerwho's Avatar
spoon fed
im going with boost in 30 days. if i dont pick up the weapon r manifold i will just fab up my own and get the j's throttle body. j's released a dbw throttle body finally. it bumps up the size 3mm.
kelso just take off the aluminum runners on your intake manifold and port match them to the head. you can port it 2mm. it really helps resonse.
Old Jan 23, 2009 | 12:01 AM
WRLEO's Avatar
For FAB Guys we also sell the Head / TB flanges and Velocity Stacks of your choice..
Old Jan 23, 2009 | 12:20 AM
kylerwho's Avatar
spoon fed
hmmm..... very nice. i will be contacting you later when i have time to build one.
thank you.
Old Jan 23, 2009 | 10:50 AM
dewthedew's Avatar
ill wait till i see people actually making numbers with these.
Old Jan 24, 2009 | 08:06 AM
FELIXY69's Avatar
so what are the HP gains with this unit
any dyno results yet ?
thanks
Old Jan 25, 2009 | 02:25 AM
WRLEO's Avatar
DYno results have been posted like months ago.. in the first thread.. results have not changed, all we did was get rid of the CEL and make sure it doesnt come back..
Old Jan 25, 2009 | 02:35 AM
WRLEO's Avatar
POSTED on FEB 2008
Ok so we did some dyno testing today and it was a bone stock fit that we borrowed from N1 Concepts. We started with the OEM baseline and then we only added the SW Intake and everything else remained stock and here is that dyno....
The next thing we did was put on the intake manifold and dyno'd here is the sheet for that. So now the car only has the SW Intake and our new Manifold everything else is stock!
Here is the last dyno which we added the Race Header to the car and the results didnt turn out too well because we still had the stock exhaust which did not help it flow. When we were doing the dyno we heard the exhaust just trying to breath so if you have a full catback you can expect alot better gains.
Here is a video of when we first put the manifold on.
YouTube - Honda Fit Weapon-R Intake Manifold
Old Jan 25, 2009 | 02:38 AM
kylerwho's Avatar
spoon fed
so how lean does the fit run with the manifold on?
i might get this to run with my FI setup later on down the road.
Old Jan 25, 2009 | 11:24 AM
WRLEO's Avatar
i have seen it run into 14.5 on the lambda but stoich is 14.3 so its not much leaner..
Old Jan 25, 2009 | 11:47 AM
cojaro's Avatar
That's some sexy manifold. DO WANT
Hand-welded?
Old Jan 25, 2009 | 03:39 PM
kylerwho's Avatar
spoon fed
that looks hand welded to me.
any chance you guys send me just the pieces of the manifold precut and put it together and weld it myself?
Old Jan 25, 2009 | 04:56 PM
FELIXY69's Avatar
impressive !!!
when i get some money !! i'll take one !
you guys have this unit on a turbod fit yet ?
Old Jan 25, 2009 | 05:51 PM
WRLEO's Avatar
yes we have it on A HKS turbo kitted fit..
Old Jan 25, 2009 | 05:52 PM
kelsodeez's Avatar
UNBANABLE
whos got an hks turboed fit around here??
