I cant remember if I posted these or not.
EWWWWWWWWWWW!!! I thought the OEM Fit offset was ugly.
dang that S is beautiful. i'm not sure about you guys but i like the look of S2K's with the hardtop. Sure it takes the fun away from going topless but still apperance wise i think it looks better than the soft tops.
what wheels are u rocking on ur fit now?
The stock ones....
I have set that aside for a "rainy supercharged day"...... (:
Awesome look! How would you rate for 16inch rims? Performance and handling wise?
+32 is pretty good you rekon +35,+36 will be ok as well? I dont like 40 plus offset.
Adding a 5mm spacer would equal out to 35mm. Just get 35mm wheels.
35mm and 32mm isnt all that big of a difference wheel wise. He could rub more than you did because of having different tires.
