Aluminum cage??
I apologize if this is a stupid question but i just had to ask... I see a bunch of companies making strut bars and such out of aluminum, so I was wondering what your opinions are about making a cage out of structural aluminum. It wouldn't be a full roll cage to support the weight of the car, just to make the car more rigid. I have A Spec front and rear strut bars and the rear strut bar I can fold in half without using much force at all, then i take a piece of structural aluminum of the same length and i can barely tweak it.
Opinions?? If you think I'm stupid... FLAME ON! :D |
Something like this? :D
Just rememeber... you've seen it first from meeeeeeeeeeeeeeeeeeee :P http://img.photobucket.com/albums/v2...619_resize.jpg http://img.photobucket.com/albums/v2...532_resize.jpg |
I wish the J's Racing one fit the USDM Fits.
Originally Posted by LiL Wee FIT
(Post 147204)
sounds like a good idea.more detail and pics if you dont get to lazy jk:D
Originally Posted by SPON FIT
(Post 147228)
off to pick up materials now. |
The basic layout
http://img244.imageshack.us/img244/3574/layouths5.jpg Upper bracket (not finished yet) http://img112.imageshack.us/img112/4950/mount1eh6.jpg Lower mounting bracket http://img244.imageshack.us/img244/975/mount2zj2.jpg Yes? No? Good? Bad? I'd like some feedback peoples... Thanks! |
you should use the c pillar bar mounting points.it will be much stronger
Use the C-pillar location, otherwise it's Mickey mouse.
Don't forget about the Progress sway bar that's available. It works well. |
C-pillar location it is.
Thanks for the input guys. :D I'll post pics as i go. |
Rear strut bar
http://img217.imageshack.us/img217/7476/strutbarhr7.jpg http://img209.imageshack.us/img209/2542/mountpl4.jpg And since the old upper mount point was a bad idea... anyone want a camera mount??? I'm gonna use the pieces for camera mounts. :) |
any progress?
i really hope that nut on top of the bar isnt the one holding the shocks in place. looks like it has about 2 or 3 threads of bite on it.
no progress yet, i've been busy with work and i have been trying to figure out ways to make a bracket for the c pillar... and no thats not the nut holding the struts in place. that nut is just for the strut bar, i have the stock nut for the rear struts under the bar. :)
(Post 147204)
Originally Posted by thejroisgo
(Post 147390)
The basic layout
Upper bracket (not finished yet) http://img112.imageshack.us/img112/4950/mount1eh6.jpg Yes? No? Good? Bad? I'd like some feedback peoples... Thanks! Very bad. Why not just modify the headliner so that you can weld the cage directly to the chassis behind the headliner mounting positions? Those screws are going to strip out and the bars are going to find themselves flying loose in the rear of your car, which poses a SERIOUS safety issue. |
I actually customed it myself... I joined the rear strut bar and the C pillar bar with two more Cpillar bars from other cars (RSX) and it worked out wonderfully :D
You fancy canucks are crazy! Here's to the Toronto Fit Club! All hail Toronto.
(Post 155728)
Just that? Two RSX C-Pillar bars and bolt em to the C-Pillar and Rear Strut Bar? SWEET!!! |
a cross bar DIY'ed or bought would be the best solution for what your asking. But if you are willing to remove the rear seets judging from your sketches why not go for a cage?
just my 2 cents |
