T1r bmax coilover question
Old Feb 7, 2009 | 03:53 AM
jdm_gd's Avatar
hi i just got my t1r bmax coilovers for my fit.. i already installed it (axel popped out ***) i was wandering if the back can go any lower??? i know i can slam the fronts but the rear is at the lowest setting but its still high.. higher than i had my springs. is there any mods or something i can do to make it lower??? ill take some pics tomorrow when i go to a local meet bet any advice would help thanks
Old Feb 7, 2009 | 10:04 AM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
If youre saying the rear is too high then you installed them wrong.
Based on pics the rears sit pretty nice with no mods.
The Skunk2's need the mods.
Old Feb 7, 2009 | 12:07 PM
jdm_gd's Avatar
well i adjusted the shocks all the way up and coils all the way down idk
Old Feb 7, 2009 | 12:57 PM
TOOL's Avatar
My sig is T1Rs all the way down.
Old Feb 7, 2009 | 09:59 PM
jdm_gd's Avatar
Ok my rear is just like tools now I guess it set in now thanks guys I gotta get some wheels on right now I got 14s on the front and 15s on the back ill post pics wen I get home from the races thanks for the help
Old Feb 7, 2009 | 11:45 PM
08fithappy's Avatar
Yes i want to see i have T1Rs on the way i can't wait to get on them
Old Feb 9, 2009 | 12:19 AM
jdm_gd's Avatar
heres night time pics i have to get the day time pics tomorrow off the other camera
Old Feb 10, 2009 | 10:06 PM
08fithappy's Avatar
Dam u have to rub^^ i don't know how low i want yet i dont really want to rub. But i don't want any space in between the wheel well and the tires. Oh also newbie question how easy is it to lower or higher the stance of the coils. I am haveing some one else install my coils and i just wanted to know how to raise them or lower them if i desiered to.
Old Feb 11, 2009 | 02:01 AM
jdm_gd's Avatar
to adjust the ride height you dont adjust the coil you can adjust the bottom of the strut up to lower and down to raise up the car. the rear is basically the same.. i found out when i installed it you can also adjust the camber where you put the bolts to the brakes.i figured that out the hard way when i noticed one side was cambered more than the other and messed up my fender.hope it helps
dannyvtek
May 11, 2017 12:20 AM
danger69
Jan 21, 2010 12:48 AM
LowBUDGETs2k
Oct 8, 2008 08:51 PM
LowBUDGETs2k
Aug 5, 2007 11:13 PM
spoonek4
Feb 17, 2007 02:24 AM
