JDM Rear Discs
Old Apr 3, 2006 | 01:17 AM
Unit 91's Avatar
JDM Rear Discs
Anyone thinking of doing this? It can't be that hard. Probably not cheap, though.
The rear drums for the NA market is semi-ghetto. Discs would be nice.
Old Apr 3, 2006 | 02:04 PM
Tech_Monkey's Avatar
Someone in this board mentioned that the Fit is sold standard with rear discs in Thailand. Supposedly, you can just order them from Honda Thailand and bolt them right on. Not sure if that's gospel truth or not. Haven't looked into it any deeper. Hope that helps.
Old Apr 3, 2006 | 02:33 PM
kentris's Avatar
Honda Jazz/Fit are sold standard with rear discs over here in the UK as well.
Old Apr 3, 2006 | 02:42 PM
HashiriyaS14's Avatar
Any idea on what the total cost of parts is?
Old Apr 3, 2006 | 05:47 PM
dougiepants's Avatar
Avid FitFreak Poster
I am curious what the total amount on the parts would be aswell, but also what the entire list of parts will include to complete the entire conversion.
Old Apr 3, 2006 | 09:22 PM
ezekielwhore's Avatar
someone on here already did it. i saw it a while back.
Old Apr 4, 2006 | 01:02 PM
EKEK88 I think is his name but that was a DC5R setp and all custom
Old Apr 5, 2006 | 02:41 AM
AJ PwR Jr.'s Avatar
Former Vendor
I have done some homework, if you want to replace the rear drums then you will need the following parts :
rear disc rotors
rear calipers and pads
rear spindle
brakelines
e-brake cable
brake fluid proporting valve
wheel hub and bearing
Old Apr 5, 2006 | 11:03 AM
corey415's Avatar
Sounds expensive. Do you have a ballpark figure of how much it costs in parts?
Old Apr 6, 2006 | 02:13 PM
AJ PwR Jr.'s Avatar
Former Vendor
I think they cost about $1400CAD approx. $1100-$1200USD for all brand new parts. I have been sourcing for used parts but they are hard to find.
Old Apr 7, 2006 | 02:47 PM
Well you do it and make sure it works and then sell it as a kit
Old Apr 8, 2006 | 12:16 AM
kennyt's Avatar
wow that's expensive... i'm sure $1400 could get me a good coilover set or an LSD...
does a car like the Fit honestly need 4wheel discs if one does not plan to turbo it?
Old Apr 8, 2006 | 03:15 PM
AJ PwR Jr.'s Avatar
Former Vendor
No one will ever complain to have more braking. More is always better than enough
Old Apr 9, 2006 | 12:33 PM
More is better, but I would like to see this conversion completed before trying it myself
Old Apr 18, 2006 | 07:59 PM
Hary Gahtoe's Avatar
I would imagine the master cylinder would/should be replaced also. Every manufacturer uses different mas.cyl. for feel & correct pressure. Don't guess, check BEFORE just changing to discs.
Old Apr 20, 2006 | 12:58 AM
mightyjazz's Avatar
Jazz GD-3 VTEC is sold standard with rear disc brake in Indonesia, but the iDSI version is sold with rear drums..
Old Apr 20, 2006 | 02:15 AM
BKKJack's Avatar
I'm the one who was talking about buying the parts in Thailand. I will take the list to a dealer and see how much.
Old Apr 26, 2006 | 08:15 PM
Popeye's Avatar
If the car takes off like Honda expects,the U.S. aftermarket will have something the works by the SEMA show in November.
Look for companies like Wilwood and Baer to jump on this ASAP,they both have kits for Scions already
Old Apr 26, 2006 | 08:25 PM
Pirelli P Zero's Avatar
If rear drums are good enough for the Spoon Fit race car, they're good enough for me. Besides, they weigh less! That's just my two cents, but yes the conversion would be cool too.
Old Apr 27, 2006 | 07:23 AM
Popeye's Avatar
No truer words could ever be spoken
