preview - only if you like coilovers
Old Dec 22, 2009 | 08:03 PM
kennef's Avatar
Originally Posted by JDMxGE8
I'm done too. Sorry for thread jacking.
you weren't thread jacking. you actually brought up thoughtful counterpoints which this platform is sadly missing in all of its aspects. suspension in particular.
honestly, i just find it hard to believe that tein really and truly put together a suspension solution that is faster than the other guys out there given the same car and driver in an unlimited class time attack. unlimited class means serious money, and means access to jrz, ohlins, moton.
Old Dec 22, 2009 | 08:10 PM
Type 100's Avatar
Originally Posted by kennef
-hyperco springs
-made to order, so there is no off-the-shelf solution.
-amr sets are in use by evo guys in rally conditions.
From my meager understanding of coilovers I know the things that can be adjusted are the valving (using/rearranging the deflected discs) and the spring rate...
Do they have any plans to release something off the shelf? Also for which Fit chassis is AMR going to make the coilovers for, GDs or GEs or both?
This looks pretty interesting...subscribed for updates
Old Dec 22, 2009 | 08:14 PM
JDMxGE8's Avatar
Now that they moved to the Unlimited Class, I believe that they should upgrade to something like JRZ, Moton, or Ohlins. The TEIN SRC was perfect when they were running in the Modifiied Class
Old Dec 28, 2009 | 05:58 PM
kennef's Avatar
I have the US GD, don't know if they are making sets for the 2nd gen.
from what i understand, off-the-shelf does not exist at AMR. which is fine even if you aren't sure exactly what you want because you have to talk to the guys at amr anyway at some point. andy did a great job with helping me choose my spring rates.
jdmjunkie561
Apr 17, 2014 08:46 AM
JdmMac
Mar 10, 2014 10:45 PM
gd_shane
26
Nov 10, 2007 10:22 PM
SBT
Oct 20, 2007 10:43 PM
Tanabe USA
May 30, 2007 06:21 PM
