Installing T1R B52 coilovers
Old Jan 9, 2010 | 02:00 PM
danger69's Avatar
So I finally got my coilover overs. I am doing research on how to install the fronts. The rears are a snap for me since I installed the progress RSB. For the fronts my main concern is adjusting the whole shock assemble. When I remove the stock assemble should I adjust the T1R to match the same height as the stock one? And any other tip those of you who have installed the T1R can help.
For the rear springs should I cover the aluminum perch with some insulation to keep the noise down?
Old Mar 13, 2012 | 07:41 PM
JohnnyAction's Avatar
How did your install go? I'm thinking about getting this suspension setup and I'm curious if you have any tips.
Old Mar 13, 2012 | 07:55 PM
SpoonInsight's Avatar
My assumption for the rear is that the coating on the coil should eliminate any noise? If you don't think the coating will suffice you could always wrap the coil area directly touching the aluminum with rubber heater hose-
danger69
California - Bay Area Community
Jun 14, 2011 05:03 PM
danger69
Jan 21, 2010 12:48 AM
Bassplayer
May 17, 2009 07:47 PM
Fit-it
13
Mar 3, 2009 03:24 PM
n0thin
Mar 22, 2008 01:46 PM
