The ECU doesn't "Choke back fuel" it simply supplies the proper amount of fuel for different temperatures ELECTRONICALLY... different operating method. :p
Chokes are MECHANICAL devices that RESTRICT incoming air (for the mechanically challenged ...."Chokes" like squeezing your neck) by reducing the volumetric efficiency of the intake system on systems utilizing a carburetor (NOTE MECHANICAL) . So NO you can not consider it choking.... Keep trying no ring yet... :rolleyes: |
Originally Posted by claymore
(Post 269779)
Nope no idle air controller on the Fit. NOTHING electrical or mechanical controlling the airflow EXCEPT the TB butterfly. The only thing controlled is the idle speed while cold but not by ANY choking system it's sensor controlled.
(Post 276356)
i already went to the dealer to perform 60K periodic maintenance and to have the rough idling check and corrected. the dealer said that after cleaning the throttle body the problem persisted. they need to evaluate the cause of the rough idling and they suspect that it might be the a/c. they said that the A/C has a delay engage. i dunno what that means...can anybody help me out? :(
Hmmmm...
I don't know but I have been (well not recently as much after my service) having issues more now with my A/C being on. Supposedly on some cars (ours?) the a/c kicks off under hard accel, but mine will act like I am jabbing the throttle after light acceleration. UGH! Oh btw I noticed that my idle does not go up when the a/c is engaged (even when I hear the compressor engage) |
