bad shifting
Old Feb 26, 2008 | 05:08 PM
  #41
Snap Fit's Avatar
very possible... for him.
I on the other hand have driven a ton of MT's
And I had the inexperience problem long, long ago. (k...maybe just long ago hahaa, im not 30 yet )
I really do need to take it in to the dealer though, as I heard a new and very annoying sound (electronic Whistle) coming from the engine, it increases as the RPM rises. It Now happens when the car is a bit cold and goes for a little while. I will see if it continues today (probably not tranny related but I had to get it out of my system on here)
Old Feb 26, 2008 | 06:03 PM
  #42
handsdown's Avatar
during the test drive i didn't shift too smoothly, but i thought it was the easiest transmission i've ever shifted... and i was smoother than the salesman according to my girlfriend.
maybe it's just because i drive a subaru, which is like cleaning a fully automatic carbine rifle everytime you want to shift.
Old Feb 26, 2008 | 06:27 PM
  #43
pcs0snq's Avatar
Originally Posted by Chikubi
I hate to say it, but I have to disagree big time here with this. There is not a 1 sec lag w/ the Fit's DBW, not even close; if there was you wouldn't be able to drive the car at all.
So here's the challenge, for 2008 MT Fit owners on here.
1) Get you car w/ eng hot and rev the eng to 3000 RPM's and hold it.
2) Now lift off the gas and watch how long the RPM's take to fall.
How long did it take before it started dropping?
On a car with a conventional throttle cable, it's instantaneous. On mine, it has notable delay on this test. I'd est 1/2 sec.
Worse yet and what I originally described
1) Accelerate and an easy pace and watch how long the RPM's hang when you have already put the tranny in the next gear, your off the gas and are ready to drop the clutch.
How long did it take. Mine is around 1 sec
It's possible I have the only Fit that does this, but being a controls engineer in real life, my guess is it's as designed like that and most other drivers just failed to recognize that or correlate it to the crappy shifting it can cause. Others are in denial
A word of explanation. The Throttle valve in our Fits "control by wire" is essentially a limited rotation motor being controlled by a program in the ECU. The gas peddle has a sensor that goes into the ECU and tells the program to open or close the throttle. To make that work, it has to be tuned so the motion is stable. If too fast it will over shoot and cause issue. if too slow it will have lag, as I have identified. Part of the programing takes into account the load on the engine. I do not have the details of the Honda Fit throttle by wire and this is how most work. Most use a "servo loop" and some use a vacuum servo, but there's no need to get into that detail.
I'll be interested to see if anyone is up to the challenge.
Old Feb 26, 2008 | 08:37 PM
  #44
pcs0snq's Avatar
Guess someone's going to take there toys and go home now.
Here read what I found.
Same issue.
A design issue for sure.....
but I was disappointed by the new model's imprecise shifter. And the new drive-by-wire throttle, which sends signals from the gas pedal to the engine electronically (in other words, there's no mechanical connection between gas pedal and engine), has a slight delay that is noticeable with the stick-shift. It's less noticeable with the optional 5-speed automatic (last year's was a 4-speed), though, and the engine's variable valve timing system helps automatic Civics feel more responsive from a dead stop than the old model.
2006 Honda Civic - Test drive and new car review - 2006 Honda Civic
more
Honda Civic 2006+ Drive By Wire Programming - CarSpace Automotive Forums
get the idea
Honda Civic EX | The Truth About Cars
WOW check this out. It's worse than I thought
Honda Drive By Wire Amendment Petition
Fit has this issue, trust me......
Old Feb 26, 2008 | 09:23 PM
  #45
randomracer's Avatar
okay it is now going away... at first i was just driving like it was cable gas and now it is getting better.... just takes some regulr driving
Old Feb 26, 2008 | 09:43 PM
  #46
Chikubi's Avatar
Same issue.
more
get the idea
Nah, I'm still here -- just at work and with the crappy weather out I haven't driven my car for the last few days, so no chance to try it.
Still, from the test you mention, what you're referring to is a bit different than what I originally thought you were saying -- I thought you meant throttle response to input while in gear, not the rev-hang when the engine revs freely. Rev-hang there is a bit of, and it's not a design flaw as much as it's there for emissions purposes. There are a number of older threads on here mentioning it.
In any case, I'll try the challenge when I drive my car next. It might not be fair though only b/c I've got a catback and intake and most definitely the response from adding those has changed noticeably since it was stock. We'll try it though just the same. More than likely, it may still be there, but after 2 yrs I'm used to it and compensate accordingly w/o thinking about it.
Last edited by Chikubi; Feb 26, 2008 at 09:58 PM. Reason: I'm stupid and can't read.
Old Feb 27, 2008 | 03:20 PM
  #47
Snap Fit's Avatar
I will try this later but I dont see it proving anything to me, as thats not really where I have my particular problem... but I will post later anyway.
I did however notice in one of your links this quote-
" Many of the younger drivers who have the energy, know-how, and sense have smartly converted their 8th Generation Civic Si DBW system to a conventional cable setup."
some random 50 yr old guy said it ^^^
interesting thought though.
really? I have not heard of this....I would think it would like undermine half of what all the electronics are doing. I know some of the other Fits made are not DBW, but are cable instead....so maybe there is a way...but man sure doesnt sound like its worth it....although it sounds nice.
Old Feb 28, 2008 | 01:00 PM
  #48
Johnson@WeaponR's Avatar
fit transmission sucks =P enough said.
Old Feb 28, 2008 | 04:19 PM
  #49
Batman's Avatar
as far as i understand, there are a few points that make this shift transition thing bad to me:
1)when you rev freely, and instantly let off the throttle, the dbw and ecu tells the car to run a few more revs before dropping the rpm's because that way, the car makes sure to burn off any excessive gas left inside, hence increasing emissions efficiency. its far from a flaw - in an emmisions standpoint.
2)hydraulic clutch system (please someone confirm if this is the design of our clutch system)
=not progressive bite
3)the shifter is soo good and direct compared to the rest of the system it makes you fell the rest of the transition is sluggish
to let you know where i'm coming from, i've worked at toyota, hyundai, nissan, infinity, and lexus, and had a chance to throughly drive most of the cars, and even though this whole drive by wire / hydro(plz confirm) clutch is not bad, its not the best to say the least
and trust me - u think this is bad - try the new lexus is250 manual
Old Feb 29, 2008 | 03:15 AM
  #50
storm88000's Avatar
Frequent FitFreak Poster
Batman - you are 100% right on. The shifter in the Fit is the best I've ever had, which is amazing considering the MSRP. I've had several M/T Nissans, 200sx SE-R, driven Corvettes, Camaros, DSM's, etc. and the Fit's shifter is still better than all.
The only thing that is as good or rivals it in my opinion is the 350Z.
Old Feb 29, 2008 | 04:19 AM
  #51
dickiez's Avatar
Originally Posted by Mark16q
I'm still not as smooth as I'd like to be on the clutch. It releases too early for my taste, and would like to adjust it so it engages closer to the floor. With the goofy steering wheel position forcing me forward a bit, its awkward on the pedals.
Any way to space the steering wheel back, which would allow a more natural gas and clutch pedal positions?
mg
i had the same thought when i test drove the car
but meh i got used to it
can sum1 explain how the reving thing works
what i mean is when you WOT then clutch it stays revved for a split second
until you engage the next gear
how does that work becuase i know the 06-08 SI's do the same thing and i thought it was a heavy flywheel or seomthing
Old Feb 29, 2008 | 04:37 PM
  #52
for those that are getting abrupt engagements pull your seat up closer
to the pedals by one click and see if that helps.
sometimes i do that when im wearing thin sole shoes to find the
clutch's sweet spot.
housemuzik
Dec 16, 2010 02:00 AM
kevinkidstar138
Jul 12, 2010 11:37 AM
Bowkr
Jan 18, 2010 06:53 PM
kancerr
Jul 7, 2008 09:41 PM
krobison
Nov 25, 2006 10:58 PM
