Wheel bearing failure people check in!
Old Sep 2, 2008 | 03:02 PM
bloke's Avatar
Mine is doing the same, after reading this i have booked an APt with Honda Service to confirm. Damm thing has 51k on it though!!!! i'll be interested if they agree it's a wheel bearing. drumming/humming sound, but it only happens on right hand turns/corners. straight lines & left turns are fine!!! i just recently had all the brakes done & 4 new tires, so i know that the car had an allignment etc. i was waiting to see if that would cure the issue but alas no.
cheers
Bandit
p.s. you're on CSi too right?
Old Sep 2, 2008 | 05:15 PM
RichXKU's Avatar
Yep I'm on CSi...
Old Sep 2, 2008 | 05:32 PM
Sugarphreak's Avatar
Push My Button
Any chance this failure has to do with the fact you run extremly high tire pressures? Maybe the tires are not absorbing as much shock from bumps and it is translating into more than just a comfort issue?
Originally Posted by wdb
Given that bearing manufacture is very automated, very measureable, and very repeatable, I expect their success rate to be in the 6 sigma range -- 3.4 bad parts per million.
I hate Six Sigma programs
Old Sep 2, 2008 | 05:39 PM
jits14's Avatar
No wheel bearing issue, but my lower control arm cracked where the ball joint is and simulated a lot of issues that I thought at first was the wheel bearing.
Old Sep 2, 2008 | 09:25 PM
RichXKU's Avatar
After about 7200 miles I don't think any condition could have caused that unless it was already bad.
Old Sep 3, 2008 | 10:07 AM
bloke's Avatar
well it went into the shop this morning we'll see what the prognosys is!
i am pissed i am out of warranty!!!!! if it is wheel bearings i might cause a stink & reference all the other cases, see if i can get somewhere!
Old Sep 3, 2008 | 02:20 PM
ClaytonS15's Avatar
Not a wheel bearing, but at 51,000 miles I've started hearing a loud clanking sound from under the driver's side front of the car when going over any kind of bumps below 30 MPG, especially any kind of stutter (repeating) bumps that upset the suspension. You could feel more vibration and shocks through the steering wheel. It turned out to be a front sway bar bushing has failed and needs replacement. The repair tech at the dealer showed me the part with the car up on a jack. Apparently it's a pretty common problem in Hondas. Looks like it'll be $170 to fix once they get the new bushing in stock.
Old Sep 3, 2008 | 03:07 PM
bloke's Avatar
Well it’s official!!!!
Just got off the phone with Peters Honda of Nashua, ($46 diagnostic fee) to confirm what I told them was wrong with it! Right Front wheel bearing!!
WFT @ 51,000 miles I am obviously out of warranty. But this seriously should not happen on a 1 ½ year old car, especially a HONDA!!!
I mentioned to the service manager, that I had read about ½ dozen incidents of wheel Bearings failing on a Honda Fits. He said he had never heard of it! EXECTLY my point I said! This is my 6th Honda, my last, a 2000 SI coupe I traded at 172,000 miles, with not a thing wrong with it! Wheel Bearings should NOT go on a 1 ½ year old car. He agreed, but obviously still wants to charge me $275!!!
I am going to write a letter to HONDA to complain to see if anything can be done.
Any thoughts or suggestions? Can I reference the cases on here?
Best
Bloke
Old Sep 3, 2008 | 03:13 PM
ClaytonS15's Avatar
Unhappy
Best
Bloke
Sorry to hear about this happening to you, and I'm kind of feeling your pain ($170 for a new front sway bar bushing at 51,000 miles). I agree that wheel bearings should not go at 51,000 miles. I put 153,000 miles on a Saab 900 and never had a wheel bearing issue. In fact it never even needed a clutch replacement. Then again, my father's 1999 Audi A4 wagon has had 2 wheel bearing failures before 70,000 miles. Maybe Honda will end up helping you out even though its out of warranty?
Old Sep 3, 2008 | 03:27 PM
RichXKU's Avatar
Best
Bloke
bum-bum-bum, another one bites the dust...
*knock-knock* Hey Honda, stop sending cars out with bad bearings!
Old Oct 14, 2008 | 12:59 PM
rlc's Avatar
rlc
My update on this subject:
2007 Honda Fit with 23538 kms (Canadian Spec) , left front wheel bearing to be replaced , under warranty.
Just had my B1 completed and added for them to check source of humming noise occuring at 60km and up , accelerating. Also occurs when de- accelerating, i.e. exiting on a freeway ramp. It was isolated to the wheel bearing. Had to come back for another appointment as the part was not in-stock. I hope this in-sight helps.
Old Feb 24, 2009 | 05:17 AM
  #32
naszero's Avatar
I just had BOTH of my wheel bearings replaced. Just a couple of miles OVER 30,000 miles. They blamed the coilover setup for the failure and promptly charged me $580
Old Feb 24, 2009 | 10:33 AM
  #33
JDM_DOHC_SiR's Avatar
Let's see.... On my GD1 that I had owned for the begining of 2002 until the the end of 2008.. I managed to go through 6....!! yes 6 wheel bearings 3 up front and 3 in the rear...1st one happened at around 12000km & the rest came about 8000km after that... Honda Japan knows this is a problem with the GD chassis Fits...I'm kind of shocked the US Honda has there head up ... well you know were..
Old Feb 24, 2009 | 11:38 AM
  #34
dang... guess i'll need to start stocking up on wheel bearings too. hahaha.
thanks for the headsup. i suppose my next wheels i'll use
15x6.5's and 42 or higher offset. (195/50/15).
Old Feb 25, 2009 | 01:49 PM
  #35
FittJedi's Avatar
Originally Posted by ricohman
for modded vehicles the most common failure was due to increased offset.
I had some rims on my 94 Cavalier that changed offset just a wee bit, but it ate through wheel bearings like Oreos. Always wondered if the two were connected.
Are there any other non-obvious issues one should be aware of if considering aftermarket rims?
Old Feb 25, 2009 | 10:19 PM
  #36
duketing's Avatar
Let's fix this wheel bearing issue once and for all
Recall all Honda Jazz / FIT due to defective Wheel Bearings Petition
Old Feb 25, 2009 | 11:23 PM
  #37
RichXKU's Avatar
Appreciate the effort man, but
1. Online petitions have never done anything, ever.
2. Recalls are only for safety issues. At most a TSB should be issued for wheel bearings.
Old Feb 26, 2009 | 12:52 AM
  #38
duketing's Avatar
Than why do they recall the Honda Civics for a wheel bearing issue.
http://nhthqnwws111.odi.nhtsa.dot.go...7V399-1316.pdf
Old Feb 26, 2009 | 02:13 PM
  #39
significant wheel bearing damage can lead to the wheel falling
off the car.
but usually before that people will know something's wrong
with their little car that sounds like a DC10 at take-off.
Old Feb 26, 2009 | 11:36 PM
  #40
HONDAMATIC's Avatar
off the car.
or seizing..
