Scan Guage owners... What is the HIGHWAY speed for best MPG?
Please mention if you have an AUTO or MANUAL because of the different gear ratios.
Suscribed……
i could be wrong but i think i read somewhere one time
that it was 59 mph. i did it a few times and it got me 42 mpg. |
I would be very surprised if it was anything more or less than "slower = better MPG".
Using pulse-and-glide (P&G) will improve mileage, if traffic conditions permit of course. |
the slower the better. and it isnt about SPEED, or RPM, its about throttle position
anywhere between 50-60 mph. i have a scanguage for sale if anyone wants one. /threadjack
I don't have a scan Gage but I use the one on my o9 auto and I have been able to get over 50 mpg doing 40-45 mpg I figure out my mpg by hand use the same pump on the same click at the same time of day lol
(Post 870694)
I think I understand what you are saying. Since air/fuel mixture is computer controlled in a narrow range, throttle position restricts the airflow, therefore fuel burn and the resulting power output. If you have ever flown an airplane with a "constant speed" propeller, its quite different. The mixture, throttle opening and propeller rpm are independently controlled manually. Manifold pressure is typically used as an indicator of power, unless you have a fuel flow meter. |
Hi gang:
**2010 Fit Sport 5-SPEED** Heres my experience with a Scangauge II equipped. I find that I can easily get the average up to 40.0 MPG on the CAR gauge by cruising at a very steady 62-63 MPH. This equates to almost exactly 3000 RPM, and a specific fuel consumption of 1.45 to 1.50 GPH. If you can stay in this configuration, the car gauge will stay on the 40 hash and sometimes stray one hash below. I use cruise control for a better result (NO AIR CONDITIONING). Its seems the car gauge is around 34-38 one hash BELOW the 40 mark, and the 40 hash is 38-42 MPG (roughly). I drove this configuration from Jacksonville to Cocoa, Florida (I-95) yesterday and averaged 40.0 exactly from start to completion. THAT SAID...this is on flat ground. Florida ISN'T flat. Overpasses require special handling to maintain economy. As I start up the front side, I tick off 4-5 presses on the cruise control a couple of seconds apart. The cruise will, by default, accelerate UPHILL. By using DECEL you force a reduction uphill. I then cancel at the crest, and glide back to 62-63 on the downhill run and reset cruise. I spend most of my time "driving by thumb" on cruise. You can achieve my settings by pointing your speedometer so it just covers the upper right corner of the "0" in "60". This will result in a tach reading just a hair above 3000 RPM. Good luck! BJK |
Speed is relative to the road and conditions...55mph on an uphill grade means lower mpg for example. Heck if you are also driving into a strong wind, your mpg can be affected.
If we are talking flat, 60-65mph should be good. I usually average 70-75 when I drive to Colorado. Lots of uphills and over all average is around 39-40mpg. I have an 07 Fit Sport Auto. |
35 to 40 5th gear.
I laugh at some of the posts. I doubt many of you have ever driven less than 55 |
Originally Posted by pcs0snq
(Post 889171)
35 to 40 5th gear.
I laugh at some of the posts. I doubt many of you have ever need less than 55 |
Originally Posted by mxl180
(Post 889174)
What is your general cruising speed in the highway?
My commutes is 24.1 miles on Interstate and posted 45 to 30mph rural streets. from cold car to interstate: 4miles 55 mpg P&G w/FAS 35 to 50 speed 3 stops and 5 lights two where DWOB timed From interstate to exit 16.2miles avg down to 49.0 55mph CC From exit to work: 7.9 miles avg back up to 52.8 Again stops and speed from 30 to 45 P&G /FAS all the way Typical for this trip and today 24.1 miles 0.45gal 2812rpm peak 1/2 hr 55mph max 41mph-avg $1.20 cost gas @ 2.64/gal US 52.8mpg SG II adjusted to agree to pump within +/-1 or 2% over many fills. This is a 2008 Sport 100% stock under the hood. Still in Dunlap's. All I have done is learn to drive it pretty good increased tire press to 60 and added a fuel pump cut off switch for the FAS Have fun!:wavey: |
I laugh at...
(Post 889171)
35 to 40 5th gear.
I laugh at some of the posts. I doubt many of you have ever driven less than 55 I use anticipation and try not to use the brakes and will shift to neutral going down a big hill (The AT wants to downshift), but I use the air and gently speed up to traffic speed and don't make a nuisance of myself driving just over the speed limit on highways. And still I get get over 31 mpg with the A/C on, which is double what I got in my Jag. If I was really concerned about mpg, I could commute on a moped...:eek: To each their own... I like the original question though, and hope someone with a scangauge can tell what the optimum speed is in an A/T (yes if I cared that much about mileage I would have gotten a manual)... |
Originally Posted by Blackbeard
(Post 889245)
Some of these posts...drive like a tard for a few mpg more?:rotfl:
I use anticipation and try not to use the brakes and will shift to neutral going down a big hill (The AT wants to downshift), but I use the air and gently speed up to traffic speed and don't make a nuisance of myself driving just over the speed limit on highways. And still I get get over 31 mpg with the A/C on, which is double what I got in my Jag. If I was really concerned about mpg, I could commute on a moped...:eek: To each their own... I like the original question though, and hope someone with a scangauge can tell what the optimum speed is in an A/T (yes if I cared that much about mileage I would have gotten a manual)... I haven't looked into it tonnes, but 40 - 45 IS the best on most vehicles, the lowest speed you can get into top gear is the best fuel economy wise, i'm not saying we should all drive 45, as it's not really an appropriate highway speed IMO, but generally your fuel consumption will just go up with speed steadily past 40-45 |
2007 MT FIT
Okay after a 200 mile trip on a highway. I find that i got worse mileage than city. i average about 34 mpg in city shifting around 2200rpm. On highway i was on 5th gear at around 75mph... no ac, windwows up. relatively flat drive with some hills... no cruise. So i think it was 3500rpm.. Ended up with 32mpg.... WTF? I don't get how you guys can get 40 mpg. Unless i drive at 60 mph i can probably get 40mpg..but that would cause many drivers to flip me off as they try to pass me. |
Your mpg does seem a little low. In comparison the very first drive on my car:
250 highway miles cruise used 90% A/C on 50% hills (up/down) 80% of distance avg speed about 73mph 36mpg calculated at the pump and could be slightly higher as previous owner filled the tank and drove some after. _ |
I have a GE Sport MT, I've found that cruising at very low speeds - say around 30-35 mph on local roads (in 5th gear) gets phenomenal fuel economy, with the engine warmed up - the MPG gauge (stock, not scangauge) reads easily over 60 mpg while cruising. so I agree - the lowest speed such that you can be in top gear, without lugging your engine will get you the best fuel economy.
I'm not endorsing the following, or admitting that I have ever done this - this is just my opinion: as for coasting in neutral on hills, it will only help you on a hill that is medium grade in steepness - on some hills, at least for MT, you will notice that you will need to step on the gas just a tiny bit, to maintain the same speed - this is when coasting will help you, and there are quite a bit of hills such that coasting in neutral will put you at a steady speed. If you coast when the hill is too steep you will go way too fast, and you should probably stay in gear for those for better control. But I feel that coasting in neutral on a medium-grade hill with a MT car shouldn't be considered dangerous since you can EASILY switch back into gear, as long as you keep your foot on the clutch and hand on the shifter. |
Originally Posted by ydnality
(Post 986790)
hmmmm I'm not sure if I am understanding you correctly - so you're saying that in some cases, leaving it in gear on a downhill will use no fuel due to fuel cut-off... wasn't sure what you were saying about 1200 rpms though
that's pretty interesting - wish I had the $$ to get a scanguage to try it out, but I definitely experienced lots of cases where putting it into neutral on hills gives better fuel economy (according to the mpg meter).. but it's gotta be the correct steepness.... seems like there's quite a bit of friction from the engine spinning at 3000 + rpms such that leaving it in gear actually makes the car want to slow down |
