MT Clutchless Shifting w/ Engine Off
I normally park in neutral and use the E brakes. But on hills, I put the car in gear after tuurming the engine off. When I do this, I don't use the clutch. I assume since the engine is not moving, this should be ok , right?
I think it should be alright since the engine is off BUT don't take my word for it though.
The clutch's main function is to of course disconnect/connect the flywheel (which is connected to the engine via the crankshaft) while it rotates in order to shift gear... so in theory, since the engine is off (flywheel not rotating) I think it would be ok when stationary. I'm not completely sure about the synchronizers for the gears though. |
Its safe because the engine is off so the synchronizers are not moving. Just dont force it because it will bent the shifting forks if the gears are not aligned. Reverse is gear you want to be in too.
I would just take the added 5 seconds to push in the clutch just to be safe IMO
Originally Posted by SilverBullet
(Post 1066630)
Originally Posted by Skyburst
(Post 1066612)
But as SB mentioned, don't force it into gear. Yes, theoretically, you should be able to shift into any gear when the engine is not running but I find the extra step of depressing the clutch while shifting into gear (1st or reverse) usually gets it done. Just my take... |
I would also definitely leave it in either 1st or Reverse, depending on which way the car would roll easier (forwards (R) or backwards (1st)). Even if the ground is completely flat, I'd leave it in gear...just seems like the smart thing to do.
(Post 1066612)
Originally Posted by Jamy
(Post 1066783)
Pretty much any gear would be fine. The car isn't going to be moving with the engine engaged unless a lot of force is applied. 2nd or 4th to be safe, but it would take a good bit to move it.
Using the clutch does nothing when the engine is off except wear the pressure plate and throw out bearing. The synchronizers are either line up or not so dont force it. I used to drive a 10 speed trans and bent forks where a big problem when drivers did not shift right because they slip seated and they did not care so they would grind the gears and force it into gear. They have dog gears which is different and the clutch is only used to start off or back up. You would line up the gears with the throttle. |
Good point SB. Reverse it is. Depressing the clutch works for me when it won't shift into gear right away. Sometimes going to 1st then reverse does the job.
I always leave it in gear when parked, been using reverse for some reason the past 30+ years.
Originally Posted by Subie
(Post 1067138)
(Post 1067383)
Using reverse is old I learned that in '79 when a friend had a Z28 and it had a reverse lock out. That was my first engine experience and would be considered slow compared to the new technologies.
If I remeber right, the gear ratio for first and reverse is the same in the fit. So either will work as well as the other. I always put it in first, even when parking flat. My driveway is steep and I use to have to park on the hill part when we had more cars so I am in the habbit of strongarming the e-break and putting it in park or first.
Originally Posted by kenchan
(Post 1066863)
if the lever goes into the gate without force, then no issue. just dont force anything.
I usually leave mine in 3rd. Its just the easiest to slide into real quick as Im coming to a stop or getting out of the car.
I've tried to put the car in gear on my gf's Jeep Cherokee without the clutch (engine off) and it just doesn't work. Clutch in, no problem. So I'm not quite sure I understand what's going on there. I've also read some concern that if you were able to overcome the force of the engine, i.e. parked on a very steep hill, it might not be the greatest of things if it caused the engine to move in reverse, say if you were parked head up and in 1st. Any thoughts there?
Originally Posted by komafit
(Post 1072787)
So if a cars breaks loose while in the opposite gear when parked in an incline, the tranny/car would be the last of your worries... :D Ouch!:wavey: |
The higher your park gear, the more likely it will roll away. It's just the nature of gearing. You can actually push a car that's parked in 5th. So I always park in first (although I'm sure second or reverse is also fine).
The clutch only helps when the wheels and/or engine is spinning. Gears grind because the drivetrain (wheel) side and engine side spin at different speeds. When the car is stopped, there is no motion whatsoever (both the engine and drivetrain are the same speed), so the clutch is absolutely pointless. I do agree that if you feel like you have to force it into gear, please don't. It can damage the synchro-mesh gears (over repeated abuse). Shift it into second and then into first and it should line up. Despite all I've said, I think I probably do still press the clutch pedal while I am parked (out of habit), but there's absolutely no reason to do so. |
Originally Posted by larrymcewin
(Post 1072831)
