Tips to Changing Your Car's Oil
Old Feb 23, 2011 | 05:34 AM
Pasqualina's Avatar
The Steps for Changing Your Oil
1. When learning how to change your oil, it is important to know that if the engine is warm, the oil will actually drain from the engine more quickly. Of course, if you elect to drive your car for a bit in order to get it warm, you must be very careful when working with the parts underneath the vehicle.
2. You should park the vehicle on ramps that can be purchased from a local or online auto accessories retailer. This will allow you more room to move comfortably underneath the vehicle. If you elect to drive up on ramps, be absolutely certain to place large cement blocks or another type of barrier that will prevent movement of the wheels.
3. Now, you will need to slide underneath the car and locate the drain plug on the oil pan. This is basically just a large nut structure with a flimsy looking washer holding it on. Once located, experiment with the sockets that you have until you find a match. Once located, turn counter clockwise to remove it.
4. Now, once this is loosened, get some old newspaper and place it underneath the drain, as well as the engine as a hole. It is important to remember that you will need to remove the oil filter as well as this could result in a spill. Once you have laid the old paper, get the container that you have designated for the old oil and place it under the drain.
5. Now, finish removing the drain plug and allow the oil to drain into the container. While this will only take a few minutes, you can move on to the next step to save yourself some time.
6. Now it is time to take your wrench that is designed to remove the oil filter and remove the old unit that is on your vehicle. You should make sure it is set up to turn in a counter-clockwise motion. Be very careful as oil will be inside of this container. Be sure to remove it so that the oil does not pour out. Once doing this, empty the contents into the drain pan.
7. Once the vehicle has been draining oil for approximately one to two hours, you are ready to put the new oil filter on. You should coat the gasket area with some clean oil and the inside of the area with some oil. Once doing this, you can thread the new filter and ensure it is put on properly.
8. Prior to placing the drain plug back on your vehicle, you should determine if a new washer is necessary. Typically, it is a good idea to use a new one so that the oil does not leak. Once the washer is replaced, you may reattach the drain plug.
9. Now, you may place the new oil into the vehicle.
10. Once the oil has been placed in the vehicle, remove the tire barriers and pull the vehicle off of the ramps. You should allow the vehicle to run for at least five minutes to ensure that there is no leakage.
JDMxGE8
Off Topic Discussion
May 4, 2010 07:06 PM
