2003 Honda Accord Oil Drain Washer Replacement
Old May 4, 2005 | 11:16 AM
Elmo P. Shagnasty
Guest
Posts: n/a
Re: 2003 Honda Accord Oil Drain Washer Replacement
In article <u8na0199g2jh0epb21nspibdpv0jqjmr03@4ax.com>,
pencilcup <dontbother@here.com> wrote:
> The Honda manual recommends that the washer be replaced with every oil
> change. As a result, I end up going to a Honda dealer and pay a
> premium for a fairly commoditized service.
You could simply make one trip to the dealer and buy a bunch of the
washers. Then you could have Jiffy Lube use them as needed.
Of course, you're never sure the Jiffy Lube guy actually uses it...
> 1) Is there a significant impact if this washer is not replaced? For
> example, every other time or once a year???
It's a one-use washer. It's a crush washer. It's designed to seal the
bolt against the pan. Once crushed, any re-use of it won't serve the
purpose. You might as well not use it.
> 2) Is it possible to buy the washer myself and have it changed at a
> non-Honda shop?
Of course. There's no magic to it.
GeneralLee86
Mar 15, 2014 09:56 AM
moolman
Apr 3, 2012 01:20 PM
quick92ciFit
Jun 12, 2009 06:55 PM
76steelers@bellsouth.net
Oct 16, 2005 11:35 AM
motsco_ _
May 4, 2005 11:16 AM
