brakes
Old Aug 4, 2005 | 10:30 PM
kathyj
Guest
Posts: n/a
brakes
i am changing rear brakes on honda accord 1994 the calipers seem to be
stuck how do you free them
Remco
Guest
Posts: n/a
Re: brakes
Stuck, as in pinching the pads to the rotor?
If so, use a C clamp spanning from the outer pad (don't put it on the
caliper, but on the pad itself) and on the inside of the brake cliper.
Tighten it slightly and that will be enough to make space so you can
slide the caliper out of the way.
Remco
Old Aug 8, 2005 | 11:48 AM
M.Paul
Guest
Posts: n/a
Re: brakes
Rear disc calipers often screw in/out to accomodate the e-brake. Using a
C-clamp could damage something!
"Remco" <whybcuz@yahoo.com> wrote in message
news:1123207253.785474.110470@g43g2000cwa.googlegr oups.com...
> Remco
Old Aug 9, 2005 | 12:39 PM
remco
Guest
Posts: n/a
Re: brakes
"M.Paul" <mpaul@NO.SPAM.sonic.net> wrote in message
news:1123514197.696941@newsreg.cos.agilent.com...
I wasn't talking about turning it in all the way with a C-clamp.
I think she had a problem getting the brakes off so my assumption was that
the caliper was holding the pad to the rotors very tightly. Putting a
C-clamp on the outer pad and the rear of the caliper assembly would push the
piston in enough to free it so you can take the pads out, t take the rotors
off, properly turn the pison back in, etc.
> > Remco
Old Sep 3, 2005 | 11:33 PM
Matt Ion
Guest
Posts: n/a
Re: brakes
The e-brake on my old '82 Subaru operated the front discs - the pistons
were a screw-in type. There were two notches in the outer edges at the
end of the piston - I would expect there's a special tool to fit them,
probably with a standard ratchet drive, but I just used a set of
Chan-nel-lock pliers to twist the pistons back in.
avast! Antivirus: Outbound message clean.
Virus Database (VPS): 0535-3, 09/02/2005
Tested on: 9/3/2005 7:55:27 PM
avast! - copyright (c) 1988-2005 ALWIL Software.
http://www.avast.com
thomas.jacobs@dva.state.wi.us
Oct 6, 2005 09:30 AM
Matthew Allen
Sep 12, 2005 09:30 PM
venom1055
Aug 16, 2005 10:53 PM
RvBTucker@gmail.com
Jul 20, 2005 10:31 PM
Cherokee
May 4, 2005 11:16 AM
