2003 Honda Accord 4 cyl gas mileage on the highway
Old Sep 9, 2005 | 03:33 PM
flobert
Guest
Posts: n/a
Re: 2003 Honda Accord 4 cyl gas mileage on the highway
On Fri, 09 Sep 2005 14:21:40 -0400, "Elmo P. Shagnasty"
<elmop@nastydesigns.com> wrote:
>In article <jae3i1t4su6d9t906l762eqek64nj8vo48@4ax.com>,
> flobert <nomail@here.NOT> wrote:
>> >ahem. Your BEST mileage will be when using cruise control.
>> You'd think so, but experimentally, in a lot of different cars doing
>> economy runs, its not. Cruise control is just to keep the car at a
>> constant speed, no to do it efficiently.
>So you're keeping your throttle at exactly the same position, manually,
>and if you go up or down a hill and your speed changes dramatically, so
>be it?
I say up front i ahven't used cruise control in years, except for once
last week. My vehicles don't have it, i don't use it. I used it on my
wifes work van, a 96 T+C. Before this, my last experiance was with a
03 buick century back in 03 (a rental car).
Basically, whenevre it droped below the set speed, it opened the
throttle to what felt like 20%, and carried on until the set speed was
reached. Personally, i'd fluctuate a bit more, run it 3 or so over,
let it run 3 or so under, and repeat. The vehicle seemed to surge as
well, as it moved into acceleration mode. and it never went over about
2500rpm, avoiding the peak torque area (which is the most efficient
area)) although whether this was more a fact of the cruise control, or
the slushbox, i don't know.
These large and drequent instances of throttle usage are not efficient
However, the wife loves the cruise control. i've asked her to make a
not of how far and how much fuel she used in the van today, and when
we do the route again, i'lm going to go with her, and drive as i
normally do, to compareThat'll be at least a week away though.
Old Sep 9, 2005 | 04:30 PM
Dick
Guest
Posts: n/a
On Fri, 09 Sep 2005 12:34:22 -0400, flobert <nomail@here.NOT> wrote:
>On Wed, 07 Sep 2005 13:11:41 -0400, "Elmo P. Shagnasty"
>>In article <4nh3v2-pso.ln1@new.helps.com>, jdhoward@helps.com wrote:
>>> To get that economy, I use no air
>>> conditioning, no cruise control
Cruise control will be an obvious help for those who cannot keep from
moving their foot up and down on the throttle on level ground without
a headwind. However, people who can keep their speed on level ground
within a couple of miles per hour can save gas when going up hill and
into headwinds. The cruise control will attempt to maintain speed
come hell or high water, even to the point of shifting down. This is
when a person with the ability to "feel" the car can get better
mileage by backing off slightly to avoid the balls to the wall effort
by the cruise. Under normal circumstances on the highway I will use
the cruise. When I get into the mountains I turn it off.
Dick
Old Sep 9, 2005 | 05:32 PM
High Tech Misfit
Guest
Posts: n/a
All good points.
I think another factor is the use of the "resume" and "accel" functions.
The first few times I used the cruise on my '93 Accord, hitting "resume" at
a speed significantly lower than the set speed resulted in the equivalent of
a somewhat heavy foot (well, heavier than mine, and I'm not exactly an easy
going driver). "Accel" produced a similar result. For that reason, when I
accelerate to get back to my set speed, I press the gas pedal myself to not
rush it, and then when I am at or very close to my previously set speed,
then I "resume". To "accel", again I press the gas pedal myself to not rush
it, and when I reach my intended speed, I "cancel" and then "set" it to the
new speed. I found that this practice increased my gas mileage by a few
miles per gallon.
Of course, this cruise control behaviour may vary among different car
manufacturers.
Old Sep 9, 2005 | 06:33 PM
Dick
Guest
Posts: n/a
On Fri, 9 Sep 2005 16:55:01 -0400, High Tech Misfit <me@privacy.net>
>All good points.
>miles per gallon.
>manufacturers.
Absolutely. I should have thought to mention that as well.
Dick
Elmo P. Shagnasty
Guest
Posts: n/a
In article <efn3i15adugoiooa593scpffimo9mth3m7@4ax.com>,
> >be it?
So you're saying you have very little experience with cruise control.
I also noticed that you avoided answering my question, so I'll ask it
again:
be it?
Is that what you're doing when you drive, to avoid the throttle
movements that are "inefficient"?
Old Sep 9, 2005 | 07:39 PM
dold@XReXX2003X.usenet.us.com
Guest
Posts: n/a
> be it?
My Datsun roadster had a manual throttle lock. I'd get to cruising speed,
pull the knob, and there I was... Mechanical Cruise Control.
Same thing for a few bucks on motorcycles, some sort of flip-lock on the
throttle. http://www.rattlebars.com/mtz/invisible.html
On roughly level ground, it worked just fine. A freeway overpass would
knock some speed off, and down the other side would overspeed, but overall
it was a pretty decent thing.
Logically, one might do the same thing with an electronic cruise control.
As my Civic starts up a grade, I have two choices: I can let the cruise
control maintain the speed, including over 5000 RPM, or I can kill the
cruise control. If it's a long grade, I let it run whatever RPM it wants.
If it's a minor grade, I kill it.
If there was some tolerance, allowing the speed to drop, programmed for a
typical overpass, cruise control could be more efficient. People without
cruise control are probably losing speed at that point anyway, so they
would never notice.
Clarence A Dold - Hidden Valley (Lake County) CA USA 38.8,-122.5
Old Sep 9, 2005 | 08:31 PM
Elmo P. Shagnasty
Guest
Posts: n/a
In article <dft65s$4bs$3@blue.rahul.net>, dold@XReXX2003X.usenet.us.com
Oh, I agree. I would like the option to be a throttle lock instead of a
cruise lock.
And with computers, it ought to be that easy.
Old Sep 10, 2005 | 01:33 AM
flobert
Guest
Posts: n/a
On Fri, 09 Sep 2005 18:25:55 -0400, "Elmo P. Shagnasty"
>> >be it?
I'm saying i have limited experiance, but with that, i pay a lot more
attention to what its doing - its not something i take for grated, and
ignore as a backgroud part of driving'
>again:
>be it?
no, i'm not. If you read what I said, I vary the cars speed, work with
the grade (and with the road thats comming up - something NO cruise
control can do) anticipate, etc.
Cruise control programming is very simple
10 IF speed<set THEN throttle++ ELSE throttle = 0
20 goto 10
Thats putting how i've seen cruise control operation to be, rendered
into 20-odd year old Basic. If the programming is more conplex, then
it certainly doesn't come across in the driving experiance.
To drive efficiently, you must drive smoothly, with no sudden speed
changes, and in harmony with the othre road users around you. A cruise
control takes no notice of any enviroment except the one its driving
over at that second, and has no way of detecting other road users. It
in no way attempts to use the engine most efficiently, so HOW can it
be driving most efficiently?
Old Sep 10, 2005 | 03:20 AM
SoCalMike
Guest
Posts: n/a
i was kinda disappointed in the mileage my 98 civic CX got going from LA
to laughlin nevada and back.
if i would have taken it easy and cruised with traffic at 70-75mph, i
might have gotten more than my usual 32mpg.
but no- i had a lead foot. some of it wasnt my fault.. some grades are
so steep i had to drop it into fourth and floor it just to keep at
80mph. 5th gear was useless, the car couldnt keep up. speedo kept
dropping, even with it floored.
and of course, i had the A/C blasting in that 114 degree desert heat,
too. the mojave desert gets damned hot during the day.
so to reiterate: thats uphill, several thousand foot climbs (2000-5000
feet at a time), A/C blasting, pedal to the metal in 4th gear, doing
80mph uphill. and the temp gauge stayed below halfway! thank gawd for
mobil1 5w30.
downside? 25mpg.
Old Sep 10, 2005 | 09:30 AM
Dave
Guest
Posts: n/a
In article <u0q4i1huh7i7rt2oj89sccafur2jipfipr@4ax.com>, flobert <nomail@here.NOT> wrote:
I can think of at least one possible way *if* the car is an
automatic. It is possible (though I do not know for a fact) that
the OEM could factor in the CC in the torque converter (TC) lockup
routine. Generally the TC locks up at a certain min rpm and for a
range of throttle positions. It might be programmed to note that if
CC is engaged, throttle-based drivability concerns will not be as
big a deal at lower rpm settings. Thus it might lock it up at
non-normal speeds resulting in a more efficient transmission.
Anyway, it has been my experience that CC probably beats my mileage.
But one factor may be that if I have CC engaged, I'm driving slower
than I would otherwise.
As to the modulating throttle, I think it is a fallacy that this
markedy decreases MPG, unless done so *aggressively*. At
least in a manual where the TC doesn't come into play. Contrary to
what you might infer from your high school driving instruction, an
engine is actually more efficient at higher (but not max) throttle
setting. Accelerating doesn't consume more fuel, braking does!
(well, accel does, but it just stores it in the kinetic energy of
the car where it is available for later use). And yeah, faster
driving means higher rpm and air drag. Both of these result in
increased frictional losses.
Old Sep 10, 2005 | 10:32 AM
Gordon McGrew
Guest
Posts: n/a
>All good points.
>miles per gallon.
>manufacturers.
After driving my heavily loaded '98 Ody through rolling hills on the
Interstate, I have found that a steep hill will cause the transmission
to downshift where I would just let the speed drop off a little.
I agree that use of resume/accell causes too aggressive acceleration.
It also lacks any intelligence. It will downshift even if it is only
3 mph below the target speed. Are newer models more intelligent?
A better solution: manual transmission.
Old Sep 10, 2005 | 12:57 PM
  #32
JXStern
Guest
Posts: n/a
On Tue, 06 Sep 2005 06:30:25 -0500, Rob wrote:
>I was concerned that gas stations would be closed based on news
>reports earlier so I wanted to be sure to do this trip on one tank of
>gas tho it turned out gas stations were open. I calculated I got 37.5
>mile/gal and I was totally surprised. I'm sure it's not a mistake
>too. Normally city driving I get around 24 mile/gal.
I believe.
I get 32-33 per tank doing mostly freeway commuting, some at 80mph,
some at 5mph, most somewhere in between, a little city driving at each
end. That's by myself, no air, mostly, and with the automatic. Flat
route, btw.
Been driving a mixed route with a 500 foot rise through the Sepulveda
pass recently, ought to measure my mileage again, doesn't seem all
that different.
J.
Old Sep 10, 2005 | 01:34 PM
  #33
flobert
Guest
Posts: n/a
Dunno if this last paragraph was directed at me or not. Engine is most
efficient at arond its peak torque area. (at least for non vtec
engines) I'm not sure about them, having not had much experiance of
them. I personally didn't learn about anything at high school (since
i'm not american, and thus never went to one) but what i learnt about
cars, i learnt in my teens, working on my fathers rally car, and doing
the old economy rally's. Those were fun, slingshotting the car around
the peak torque area, and using a saab freewheeling unit in between.
Old Sep 10, 2005 | 06:31 PM
  #34
Dave
Guest
Posts: n/a
In article <uc46i1dani1j10hvtrqumkhuooolutm3bl@4ax.com>, flobert <nomail@here.NOT> wrote:
>engines)
I think that is close, but at peak torque, most if not all engines
go into fuel enrichment. So, they won't be terribly efficient
there. Highest efficiency is typically about 20% or so below the
peak torque for that rpm judging from the fair number of brake
specific fuel consumption maps I've seen. That's still a very high
throttle setting which you won't see in typical cruise.
  #35
flobert
Guest
Posts: n/a
>>engines)
Possibly a difference between US and EU tunes
Old Sep 11, 2005 | 12:31 AM
  #36
slim
Guest
Posts: n/a
> <Rob> wrote in message news:4dvqh1pinsv24o2bu5vb004dpq8gsd9034@4ax.com...
> > Just thought this gas mileage story might be worth noting for some
> > Honda Accord buyers.
> > I just took my first long ride with this car this past weekend from
> > Houston, Texas to Austin, Texas and back. I used cruise control 99
> > percent of the time and had 2 adults, 2 teenagers and baggage and air
> > conditioning 100 percent of the time. I locked in the cruise control
> > at about 66 or 67 mph (speed limit said 70) and just stayed mostly in
> > the right lane to allow cars/trucks to pass me.
Why not keep up with the pace of traffic rather then being an hazard?
Donald Rumsfeld: "If you're asking if there's a direct
link between 9/11 and Iraq, the answer is no."
http://msnbc.msn.com/id/4865948/
On May 01, 2003, President Bush declared that,
"Major combat operations in Iraq have ended."
"I'm the commander -- see, I don't need to explain --
I do not need to explain why I say things. That's the
interesting thing about being the president.
Maybe somebody needs to explain to me why they
say something, but I don't feel like I owe anybody
an explanation. "
- George "Dubya" Bush
Old Sep 11, 2005 | 03:30 AM
  #37
John Horner
Guest
Posts: n/a
Not neccessarily. Cruise control increases the throttle opening for any
slight incline. Practiced fuel economy drivers will let a little speed
bleed of on modest uphill inclines and then let it build back up going
down the other side.
For *most* drivers, cruise control can improve fuel economy. However,
for those rare drivers who have studied the art of fuel economy
maximization ... ya can do better.
John
  #38
John Horner
Guest
Posts: n/a
Re: Honda CR-V rotor lifespan
Ralph wrote:
> The dealership says my sister's rotors must be replaced 'because they're
> rusting'.
> The CR-V has 60,000 km on it. Is this normal wear?
> Your expert opinion is invited... thanks, Jack.
BZZZZT! Yellow flag scam possibilities. Rust is not a reason to
replace rotors. Insufficient thickness, deep groves and warping are all
possible reasons for replacement.
Old story, old scam.
John
Old Sep 11, 2005 | 02:30 PM
  #39
Sparky Spartacus
Guest
Posts: n/a
>>>>be it?
>>again:
>>be it?
Exactly what does this entail? And doesn't traffic interfere with your
careful anticipation? People doing a constant 50 around here are in
danger of being crushed by Yugos running on one cylinder.
Old Sep 12, 2005 | 08:31 PM
  #40
Pars
Guest
Posts: n/a
> mobil1 5w30.
It was probably the A/C and the desert heat that sapped a lot of the power.
In 4th gear, while climbing mountain (in Hamshire & Vermont) I'm able to
maintain 105 mph, but that's on a nice cool (65 degree) day with no AC
equipped. If you're racing up a hill and your speed is under 100mph, 3rd
would be the preferred gear, instead of 4th. While climbing a particularly
steep hill in 3rd gear at high speed, frequently I'd have to pass on the
right (those pick-up drivers have a lot of attitude, especially when there's
a small car bugging their ass on the left lane).
30 mpg is about right for aggressive driving situation and slowing the speed
down to 50 mph would return a huge improvement on fuel consumption (like 40
mpg or 50mpg on a cool day with fairly level grade).
Also, after 250,00km of driving, I've yet to see my temperature gage go
beyond the 2/5 mark. The big engine compartment with lots of free space
helps.
Pars
98 Civic Hatch
> downside? 25mpg.
