edo-competition Lamborghini Murcielago LP710/2
Old Aug 3, 2008 | 12:20 AM
Sid 6.7's Avatar
Why so serious?
edo competition -HOME-
German tuner edo competition is determined to leave no supercar untouched, and the Lamborghini Murcielago LP640 is the latest to undergo the conversion. Starting with the 6.5L V12, edo adds high performance camshafts, upgraded cylinder heads, and new high flow air filters. The exhaust system is also reworked, including new headers, high-flow cats, and new mufflers. The result is 710 horsepower and 516 lb-ft of torque, good for a 0-60 mph sprint in 3.2 seconds and a top speed of 224 mph. Additional modifications include a conversion to RWD, 19-inch alloy wheels, and a new aerodynamically efficient adjustable rear wing. Follow the jump for full details in the press release and check out the gallery below.
Anyone searching for the exceptional simply has to look to edo competition. Tapping its roots as one of the ultimate performance vehicle tuners, the company from Ahlen, Germany has turned its eyes towards a very special car, the new Lamborghini Murciélago LP 640. The already extremely capable monster has been turned into the world's fastest and most powerful Lamborghini by edo competition: the edo LP710 /2.
The increase in power was achieved through the use of new exhaust headers, new high flow catalytic converters, new mufflers, a new exhaust tip, new performance camshafts, modified cylinder heads and new high flow air filters. The engine controls are reprogrammed to make ideal use of the individual modifications. This powerful package is brought to perfection with optimized aerodynamics which enhances the stability of the mighty bull and bestows the car with an even more dynamic elegance. A newly developed and beautifully shaped rear wing with an adjustable lip completes the aerodynamics package. A high-speed wheel and tire combination: 19 inch light alloy wheel set with special Continental high-speed tires: 225/35 ZR 19 Continental V-max in the front and 325/30 ZR 19 Continental V-max in the rear.
High performance exhaust system
A marvelous sound emanates from the edo competition stainless steel high performance exhaust system which includes a new exhaust tip. A new butterfly-valve control system – remote-controlled on request – is available, too. The more aggressive rear view is a great side-effect.
Drivetrain/clutch
edo competition has developed a new single disc clutch. Additionally the 4-wheel drive arrangement is turned into a 2-wheel drive setup. The LP 710 /2 is delivered with rear wheel drive. Weight savings of 40 kg (88 lb) and more agile handling are the result of this conversion. All modifications are carried out exclusively at edo competition Motorsport GmbH in Ahlen.
Specifications
Engine 6.5 ltr. V12
Power 710 hp / (522 kW) at 7625 rpm
Max. torque 700 Nm (516 ft-lb) at 6400 rpm
Performance
Top speed > 360 km/h (> 224 mph)
0 – 100 km/h (0 – 62 mph) est. 3.2 s
0 – 200 km/h (0 – 124 mph) < 10 s
Features
Engine:
  • New ECU calibration
  • New exhaust headers
  • New performance camshafts
  • Modified cylinder heads
  • Newly developed high flow catalytic converters
  • New high flow mufflers
  • New stainless steel exhaust tip
  • New exhaust butterfly-valve control (with remote)
  • New special air filters
  • 49.500,00
High performance exhaust system:
Super sound high performance exhaust system in stainless steel with butterfly-valve control, remote and new exhaust tip
High-Speed wheel/tire combination:
Front: 225/35 ZR 19 Continental V-max. Rear: 325/30 ZR 19 Continental V-max.
Wheel/tire combination:
Wheels: custom painted on request
Body:
Specially designed rear wing with adjustable lip
Drivetrain / clutch:
Newly developed single disc clutch.
The 4-wheel drive arrangement is turned into a 2-wheel drive setup. The LP 710 /2 is delivered with rear wheel drive. Weight savings of 40 kg (88 lb) and more agile handling are the result of this conversion.
Interior:
Rear view camera
Tire pressure monitoring system
Exposed carbon fiber interior trim
You guys need to start droppin' tha rep with all these awesome car threads I'm laying down!
Sid 6.7
Oct 5, 2009 12:51 PM
Sid 6.7
Jan 9, 2009 09:34 PM
Sid 6.7
Dec 23, 2008 10:26 PM
Sid 6.7
Oct 1, 2008 09:05 AM
Sid 6.7
Aug 3, 2008 12:39 AM
