Lexus IS C (F-Sport)
Old May 16, 2009 | 11:23 AM
Sid 6.7's Avatar
Why so serious?
In an effort to appeal to its more performance-minded customers, Lexus launched its F-Sport line of accessories at SEMA in 2007. Available for the IS model, the parts ranged from a ceramic brake upgrade to a beefier clutch that could handle 15% more torque. Coinciding with the launch of its IS hard-top convertible, Lexus is also introducing a line of F-Sport accessories available for both the IS250C and IS350C that will be available at the same time the cars hit showroom floors. Parts include 19-inch forged alloy wheels, upgraded brakes, performance suspension system, high-flow air intake, exhaust systems, and more. All of the accessories have been developed by Toyota Racing Development (TRD) and are warrantied for 12-months or for the remainder of the car warranty, whichever comes first.
F-Sport 19" Forged Alloy Wheels
This lightweight forged alloy wheel, exclusively designed in a dark graphite finish, includes a staggered fitment with 19" X 8" front wheels and 19" X 9" rear wheels. Recommended tire sizes are 225/35R19 in the front and 255/35R19 in the rear.
F-Sport Front Brake Upgrade
The Front Brake Upgrade provides a firmer pedal feel and improved fade resistance in repeated severe duty use. The Brake features six piston fixed calipers, and drilled cast iron 355mm diameter rotors with a patented internal fin design mounted on anodized aluminum hubs. Braided stainless steel brake lines and low-dust performance brake pads are included and the upgrade can be used with stock or F-Sport upgraded rear brakes.
F-Sport Rear Brake Upgrade
Similar in construction to the F-Sport Front Brake Upgrade, the rear brake upgrade uses four piston fixed calipers and drilled cast iron 345mm diameter rotors. Braided stainless steel brake lines and low-dust performance brake pads are also included. The Rear Brake Upgrade may only be used in conjunction with F-Sport Front Brake Upgrade.
F-Sport Continuous Carbon CeramicTM Brake Upgrade
A new generation of carbon fiber-reinforced ceramic material technology maximizes high-temperature durability and system cooling in this ultimate upgrade for the IS F. Ceramic rotors measure 380mm diameter front and 355mm diameter rear on anodized aluminum hats. They incorporate the same internal cooling vane concepts as the F-Sport cast iron rotors, while significantly reducing unsprung and rotating mass compared to the IS F stock brake system. Distinctively finished six-piston front and four-piston rear fixed calipers signify leading-edge technology and performance. Specially qualified performance brake pads and stainless steel brake lines are included.
F-Sport Exhaust System
This system features all stainless steel construction with fully polished mufflers and double-wall exhaust tips. In addition to an outstanding appearance, it delivers a powerful, sport-tuned exhaust sound.
F-Sport Lowering Spring Set
This feature lowers the vehicle approximately 1" in the front and rear for a more aggressive appearance and a lower center of gravity. The spring set is engineered to deliver lowered ride height without bottoming out or creating a harsh ride. The feature can be used with either the stock or F-Sport shock absorber set.
F-Sport Sway Bar Set
This includes a set of larger diameter, replacement front and rear sway bars that offer reduced body roll and flatter cornering. Urethane mounting brushings are also included to replace the original rubber brushings.
F-Sport Bilstein Shock Absorber Set
Developed in cooperation with Bilstein and available exclusively through the F-Sport Performance Accessory program, this shock absorber set offers sport-tuned suspension dampening without sacrificing ride quality.
F-Sport Clutch
The F-Sport Clutch increases clamping force approximately 15% to handle higher torque capacity and provide improved feel.
F-Sport Quick Shifter
Engineered and machined from billet aluminum, the F-Sport Quick Shifter decreases shift throw by approximately 30% for positive shifting.
F-Sport Rear Chassis Member Brace
To improve chassis stiffness under aggressive driving conditions and provide a more responsive feel during cornering, the F-Sport Rear Chassis Member Brace joins key rear chassis and suspension mounting points through this tubular steel brace.
F-Sport Carbon Fiber Engine Cover
Constructed from real carbon fibers, this very light and durable engine cover provides a high-tech appearance under the hood. This is a direct replacement for the original cover and is only available for the IS 350.
F-Sport Air Intake
This low restriction intake and filter assembly is fully compatible with stock engine controls and is emission legal in all 50 states.
Lexus Genuine Accessory Ground Effects Kit
For a lower, more aggressive appearance, this color-keyed four-piece body kit includes front and rear valences and side skirts.
Lexus Genuine Accessory Rear Spoiler
This rear deck mounted, color-keyed lip-style spoiler provides the finishing touch for the sport-tuned enthusiast.
Old May 16, 2009 | 12:37 PM
nice features but it still looks kinda werd...
Old May 16, 2009 | 02:14 PM
Koi's Avatar
Koi
I like it. The back is a bit too tall (got the lancer/mazda thing going) but at least it doesn't have fake quad exhaust pipes like the IS-F.
Old May 16, 2009 | 02:40 PM
TekXoID's Avatar
sweet accessories but wtf is up with the body style change? I like the sedan generation much better...
Old May 16, 2009 | 07:05 PM
Fit of RAGE's Avatar
looks like it might be a hard top convertible.
Old May 16, 2009 | 07:30 PM
Contrabida Face's Avatar
this car is secks
Old May 16, 2009 | 11:40 PM
doctordoom's Avatar
Supervillain
i like the sedan better but maybe i'll change my mind when i see this in person. probably not though.
Sid 6.7
Mar 14, 2009 02:12 PM
Sid 6.7
Feb 12, 2009 03:51 PM
Sid 6.7
Jan 22, 2009 06:32 PM
Sid 6.7
Dec 23, 2008 10:26 PM
Sid 6.7
Aug 3, 2008 12:20 AM
