The Ultimate Parts Required to Update USDM GE Fit to JDM GE Fit Parts thread
Old Sep 3, 2008 | 11:27 PM
JDM_DOHC_SiR's Avatar
Exclamation The Ultimate Parts Required to Update USDM GE Fit to JDM GE Fit Parts thread
This thread is going to be a work in progress... that will include part #'s ( if available ) and such. Hopefully this will help all of you trying get parts or convert your USDM 09 Fit to JDM GE specs... . .
( JDM Front end parts required )
1) Hood, P/N 60100-TFO-000ZZ
2) Front Bumper, P/N 71101-TFO-J00
3) Front Re-bar, P/N 71130-TFO-000ZZ
4) Right Fender, P/N 60211-TFO-J00ZZ
5) Left Fender, P/N 60261-TFO-J00ZZ
6) STD Right front light, P/N 33100-TFO-003
7) STD Left front light, P/N 33151-TFO-003
8) Front radiator support assy kit ( 5 pieces total, 4 of them need to be welded in ), P/N 60400-TFO-300ZZ
9) Front grill, P/N 71121-TFO-J01
10) Lower front bumper grill, P/N 71103-TFO-J00
11) Hood latch assy, P/N 74120-TFO-T01
12)
13)
14)
15)
16)
17)
18)
19)
20)
21)
22)
23)
24)
25)
26)
27)
28)
29)
30)
( there is a few more nickel and dime parts that are needed for the front... working on getting part #'s )
( JDM Rear Bumper parts required )
1) Rear Bumper, P/N 71502-TF0-000
2) Lower Rear Bumper insert, P/N 71502-TFO-J00
( JDM LED Taillights )
1) Right LED light assy, P/N 33500-TFO-J01
2) Left LED light assy, P/N 33550-TFO-J01
( JDM Non-LED Taillights )
1) Right STD light assy, P/N 33500-TFO-003
2) Left STD light assy, P/N 33550-TFO-003
( JDM Clear LED 3rd Brake light )
1) Clear 3rd brake light, P/N 34270-TFO-J21
( JDM Power folding mirrors with turn indicator )
1) Right LED Folding mirror, P/N 76208-TFO-J11
2) Left LED Folding mirror, P/N 76258-TFO-J11
3) Power folding type mirror switch assy, P/N 35190-TFO-J01
4) LED winker light right side, P/N 34300-TFO-003
5) LED winker light left side, P/N 34350-TFO-003
6) LED side mirror cover Tidewater Blue, P/N (Right) 76201-TFO-M01ZC (Left) 76251-TFO-M01ZC
7) LED side mirror cover Crystal Black, P/N (Right) 76201-TFO-M01ZD (Left) 76251-TFO-M01ZD
8) LED side mirror cover Taffeta White, P/N (Right) 76201-TFO-M01ZE (Left) 76251-TFO-M01ZE
9) LED side mirror cover Storm Silver, P/N (Right) 76201-TFO-M01ZG (Left) 76251-TFO-M01ZG
10) LED side mirror cover Milano Red, P/N (Right) 76201-TFO-M01ZL (Left) 76251-TFO-M01ZL
11) LED side mirror cover Blackberry Pearl, P/N (Right) 76201-TFO-M01ZJ (Left) 76251-TFO-M01ZJ
12) LED side mirror cover Blue Sensation, P/N (Right) 76201-TFO-M01ZB (Left) 76251-TFO-M01ZB
( JDM Side Mirror Lens Wide View )
1) Aqua Clean mirror/ lens set, P/N 08V11-TFO-000
( JDM Rear Disc Brakes )
1) Right/Left rear disc, P/N 42510-TFO-000
2) Right/Left rear hub assy, P/N 42200-TFO-000
3) Right rear caliper assy, P/N 43018-TFO-000
4) Left rear caliper assy, P/N 43019-TFO-000
5) Right rear sensor assy, P/N 57470-TFO-013
6) Left rear sensor assy, P/N 57475-TF0-003
7) Rear Trailing arm assy, P/N 42100-TFO-N05
( JDM Glass roof parts )
1) Upper glass roof assy, P/N 68100-TFO-J10ZZ ( this is just the glass only and it is some serious $$$$$ )
2) Inner headliner, P/N ???
3) Rear roof structure assy, P/N ???
4) Window gasket assy, P/N ???
( JDM Badges )
1) RS emblem, P/N 75731-TFO-003
2) Front Type-R badge, P/N 75700-SNW-003
3) Rear Type-R badge, P/N 75700-S5T-E01
4) Type-R Key cover, P/N 35114-S6M-Q11
5) RSZ Rear emblem, P/N 75731-SMA-003
6) RSZ Front grill emblem, P/N 75732-SMA-003
7) RSZ Steering wheel emblem, P/N 77810-SMA-J71
( Front Suspension Parts )
1) Front camber adjustment bolt, P/N 90188-SCC-A00
( Rear Cargo area Dual Stage light )
1) Rear Cargo light, P/N 34265-SFE-003
( Misc. Interior/Exterior items )
1) Red JDM Hazard switch, P/N 35510-SYP-003
2) JDM Center console front lower cover, P/N 83403-TFO-003ZA
3) JDM Center console front coin holder, P/N 83404-TFO-003ZA ( need above part # to use this )
4) Euro Twin Horn. P/N 08P80-TF0-000
5) Carbon look interior door panel garnish, P/N 08203-TFO-700GX
6) JDM Rear hatch upper spoiler ( small type uses same bold holes as USDM rear spoiler ) , P/N 08F02-TFO-750AX
Old Sep 4, 2008 | 12:20 AM
Pirelli P Zero's Avatar
Thanks for the great info. Keep it coming!
Are you aware of whether or not the headlights themselves will swap without other mods? The housings look to be very similar dimensions.
Old Sep 4, 2008 | 12:21 AM
Spooling's Avatar
Where can you find an importer in north america? my friend wants to know desperately
Old Sep 4, 2008 | 01:50 AM
Thanks..
I'm looking into the part #s right now.. but I know for a fact that the HID assy light is very different than the standard ones, there seems to be an option with auto headlight adjustment from the inside of the GE6~9 and it makes the housing assy larger in the back... they are also shorter in lenght that the USDM ones by about 2~3 inches...
Old Sep 4, 2008 | 09:55 AM
jdmgab's Avatar
How about adding AWD
Just saw this on the Honda Japan Website.
Old Sep 4, 2008 | 05:51 PM
Sould have a few more part#s to add to the list in a few hours...
Old Sep 4, 2008 | 11:20 PM
Dersch's Avatar
How bout the base model rear taillights (since they look completly diff then USDM or RS )
The base model is not LED?
and do the HID headlights come with a darker housing?
Old Sep 5, 2008 | 05:42 AM
Base model part # is listed above
and for the headlights the RS is the one that has the darker housing ... HID or HALOGEN type..
Old Sep 5, 2008 | 08:49 PM
Updated list with more part #`s to include rear disc brakes & LED folding mirrors ...
Old Sep 6, 2008 | 02:36 AM
Dersch's Avatar
They get rear discs brakes too? Sometimes i hate being in NA
You were saying that the headlights (especially the HID ones) were bigger in the back...so wouldnt work on usdm? or with converting the front bumper/parts it would fit?
Old Sep 6, 2008 | 02:57 AM
ctsport's Avatar
thanks for the great info!JDM_DOHC_SIR!
by looking at the parts list, it looks like it'll cost a small fortune for this conversion
Old Sep 6, 2008 | 08:32 AM
Your welcome.. just trying to help everyone out ...
Old Sep 7, 2008 | 09:15 AM
peanut's Avatar
JDM_DOHC_SiR, are the differences between the two markets just on the exterior of the car? I'd like to know if there is a reasonable way to add Refresh mode back in. I find it silly that the USDM brochure calls "People mode" a feature.
I also believe the Fit features a "ULTR" luggage floor in the back. Probably won't work with the spare tire in the USDM model, but from the looks of it on the Japanese website, I think the only product truly missing is that middle shelf accessory.
Great job on that parts list so far!
Old Sep 8, 2008 | 04:08 AM
As far as the Refersh mode I belive that you would have to use the JDM front seats..... since it looks like the USDM seats have been made larger for us ( BIG PEOPLE ).. .... Anyways..
Now for the Rear ULTR floor in the back... there is actually 3 different versions the middle shelf is actualy the floor it self that folds up to produce it and to allow storage in the area that the spare tire would sit on the USDM fit.. Have a look at the following diagram #2 is what would be needed to have the mid shelf option.
Thanks for the props`
Old Sep 9, 2008 | 01:52 PM
abu's Avatar
abu
Does anyone know if we get the jdm rear disc parts listed above, will it just bolt right on?
Old Sep 9, 2008 | 03:01 PM
Tastycakes's Avatar
You say update as if the US has an old version .
IMO the JDM looks like crap, too much like a Yaris and a creature found on pok-e-mon.
It would be nice tho to get that little compartment that fills the spare tire.
Oh hey do you got the part #'s for the sky roof?
Old Sep 9, 2008 | 04:47 PM
Originally Posted by Tastycakes
It would be nice though to get that little compartment that fills the spare tire.
Yes I have the part #s for the sky roof and the rear compartment flooring... just getting a few more part#s together
Old Sep 9, 2008 | 11:29 PM
Tastycakes's Avatar
Wonder how hard it would actually be? For the sky roof. Man it sucks we dont get it, that was my main deciding factor for the Fit. :/
Reminds me of old Trans Am's. If you got a model w/o the T-Tops you could literally cut the roof off and it had the sub frame already built there to accommodate T-Tops.
Old Sep 10, 2008 | 03:31 AM
Hope you have hook ups at a body shop.... some serious coin no doubt
Old Sep 10, 2008 | 09:02 PM
Dersch's Avatar
Thought about doing the same...at the same time the early adopters will get screwed as the sky roof will probably be ava 2nd or 3rd year in
